General Automotive Discussion
'95 SHO problems
Old Jul 1, 2006 | 02:38 PM
jimbo beam's Avatar
jimbo beam
'95 SHO problems
hey guys, my buddy just bought a 95 sho, auto 3.2L 170,xxx miles, it ran great for a few days then it started shifting real hard. it bangs into drive when moving from park, he has to manualy shift it, and it wont stay in drive, it will bounce back and forth between 2nd and 3rd every couple of seconds. also the car will not start right away you have to hold the gas to the floor and crank it for a few seconds to get it to start, once its started it seems to run ok.
we're thinking its got a vacuum leak somewhere, when the car is idleing you cant notice anything but when its reved a little you can sometimes hear a vacuum like hiss. we've looked around under the car, and replaced a few real bad looking vacuum lines.
trying to do anything on these yamaha motors is like trying to do brain surgery, its a whole differnt world compaired to my old 300.
also, for what its worth the motor mounts are toasted on this car, with the car in gear holding the brake and pushing the gas a little the motor rocks foward and back about 6 or 7 inchs, could that throw the tranny out of wack or something?
if you guys can offer any advice that would be great, hes only had the car a week and its spent the last 5 days just sitting in the drive way.
Old Jul 1, 2006 | 03:31 PM
Rockledge's Avatar
Rockledge
Pull the codes and post them:
http://www.shophoenixproject.com/eec/eec.htm
The tranny issue could be a bad VSS, but see what the codes say.
Reinforced mounts are the only way to go. Best place to get them is HERE.
Old Jul 10, 2006 | 07:05 AM
76F250Gal's Avatar
76F250Gal
www.shoforum.com is another great place to look if you want help. There's a lot of knowledgeable guys there.
