fuel guage
Old Jul 1, 2006 | 11:53 AM
460man's Avatar
460man
fuel guage
i just replaced my gas tank with a new one that was in my previous 79 so i now the guage used to work. well i put in my new 79 and the guage reads nothn. i checked the wiring where it plugs into the tank.. is there anyway i rewire the whole thing. any ideas?
Old Jul 1, 2006 | 04:03 PM
Mil1ion's Avatar
Mil1ion
It needs to be grounded
The Ford indicating systems work on " signal plus ...ground-out"
Is there a pulsing 5 volts at that SU wire connection with the key on ?
Old Jul 1, 2006 | 08:36 PM
460man's Avatar
460man
i screwd wire to the frame. so i dont no why it wouldnt be grounded could it b the guage
Old Jul 1, 2006 | 08:50 PM
tanman722001's Avatar
tanman722001
Sometime you need to clean the frame where the wire grounds at.
Old Jul 1, 2006 | 11:19 PM
Mil1ion's Avatar
Mil1ion
Test the harness first with a multi-meter for a PULSING 5 volts.
If that pulsing voltage isn't there ...the gauge won't read.
The other way is to figure it out is .....ground out the S/U connection and then go turn the ignition Key to RUN position.....check the fuel gauge ...if the gauge pins to the high side, the circuit has power.
Old Jul 3, 2006 | 11:27 AM
73Custom's Avatar
73Custom
Usually the problem is cracked/broken wires or bad ground. If the wire along the frame looks cracked - replace it. Be sure to solder all splices and clean the ground point with sandpaper and coat with dielectric grease.
Marty
Old Jul 3, 2006 | 11:40 AM
HonorableKingCab's Avatar
HonorableKingCab
I worked on a Ford fuel gauge this weekend. We couldn't locate the problem because all the electrical worked fine at the guage and at the sending unit. After the unit had been out of the tank 10-15 minutes, we noticed the float was still wet. After close inspection, there was a hairline crack in it. It would take on fuel and drop to the bottom. A new float solved the problem.
At least it's another place to look in your case.
Old Jul 3, 2006 | 01:14 PM
Mil1ion's Avatar
Mil1ion
Thanks for the reminder
although I have that condition listed in my "Guage reads empty" check list.
In this case the OP replaced the tank which would involve removing the SU and thus if it had fuel in it would be noticed right away.
Although there is the coincedence factor and that float may have filled up when he put gas in the new tank
Old Aug 22, 2006 | 09:30 AM
cowboyty's Avatar
cowboyty
I have no power at sending unit, but there is power at the guage. But haven't found power coming out of the instrument cluster. Which color is coming out of the cluster plug? I know the wire going to the sending unit needs replaced too. The ground wire isn't in to good of shaped but it grounds fine. I will replace it when I replace the power wire coming back. Then I will check to see if the su works or not. Thanks
Old Aug 22, 2006 | 12:57 PM
Mil1ion's Avatar
Mil1ion
What's the power at the gauge ?
Check the instrument cluster voltage regulator for a pulsing 5 volts.
http://www.clubfte.com/users/mil1ion...strations.html
Old Aug 25, 2006 | 09:04 AM
cowboyty's Avatar
cowboyty
will the power wire at the sending unit have a pulsing 5 volts? I plan on checking it tonight if i get a chance since i have replaced the power wire to the sending unit and replaced the ground wire with good ground. Or is the votlage regulator the little box thats attached to backside of the cluster that has circut running to the fuel guage?
Old Aug 25, 2006 | 11:37 AM
Mil1ion's Avatar
Mil1ion
Yes 5v pulsing at the sending unit.
Make sure you have a very good ground before you test it though.
Use a jumper wire and go to a point where you know it a good clean ground.
I common problem for those who say they don't get a signal is that they are trying to ground to a rusty frame.
Old Aug 25, 2006 | 12:01 PM
cowboyty's Avatar
cowboyty
I wire brushed the frame where I hooked my ground wire, but I will double check it and when I test it I will run a jumper to neg battery.
Old Aug 28, 2006 | 08:33 AM
cowboyty's Avatar
cowboyty
I checked it this weekend and with new jumper wire to the neg battery terminal to the power wire of sending unit has 0.01 volts pulsating. I have the same using the ground wire to power wire. Do I need to try it through the sending unit or not? Or where do I need to look for a new problem? Thanks
Ty
Old Aug 28, 2006 | 11:40 AM
Mil1ion's Avatar
Mil1ion
Pull the cluster and check the ICVR contact for full 5V power.
They do go bad.
