Timing?
Old Jun 30, 2006 | 11:09 PM
Munch's Avatar
Munch
Timing?
I have a 1978 F250 4x4. The engine is a 400 take .30 over. It was totally rebuilt and it is just being broken in, driving it around tho it seams to be ******* a little. I have the timing set at 8 degrees adv. Is this to much, what should the timing be at?
Here is what the engine involves:
-400ci +.30
-cloyes timing chain (ran straight up)
-Comp Cam XE262
-edelbrock performer intake
-carter 650 carb
-summit long tube headers
-stainless steal valves
-10 degree retainers and locks
-Comp Spring matched to the Cam
-advance curved distributor
Old Jul 5, 2006 | 10:14 PM
Bronco80's Avatar
Bronco80
Advance it a little and see if it peps up.
Just watch out for pinging.
That means you have gone to far.
Old Jul 6, 2006 | 03:25 PM
seneca's Avatar
seneca
Smile timing advance/400
My setup is about the same as yours ---except mine is a 400- .060 over with a Comp. deh 265. I set mine at 18 degrees btds and it responds instantly.
My truck's name is Knarly.
Old Jul 6, 2006 | 03:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
18° Initial timing is WAY to much. Something must be wrong with the way the distributor is set up or working to require that much advance. Or you could be mesuring it incorrectly. Timing should be around 8-10° BTDC and the distributor should be set up near the following if you do not have EGR. EGR requires different advance numbers.
1971 distributor & engine specifications for the 400:
This was the GOOD year for the 400 engine before it was smogged to death.
Distributor part #D00F-U
Centrifugal Advance Start: 0-0.5° @ 350RPM Finish: 14° @ 2275RPM
Vacuum Advance Start: 0-1° @ 5" Finish: 12.5° @ 25"
Point Dwell: 26-31°
Initial Timing: 10° BTDC, 6°BTDC California.
Vacuum given in inches of Mercury (Hg).
RPM specified as distributor RPM.
Degrees specified as distributor degrees.
Double those values for crankshaft figures:
Example: 0-0.5° @ 350RPM distributor becomes 0-1° @ 700RPM on the engine.
Old Jul 6, 2006 | 04:24 PM
dada's Avatar
dada
I'm glad Eric responded first on the 18... kinda hard to believe... mine would ping on the slightest pedal tromp... I have the same basic setup as the first guys but went with the 255DEH based on towing needs... I run around 8 BTDC and I too sense a bog accelerating in lower RPM's, once I hit mid-range it's off to the races... I have attributed some of this to my 32"TSLs and 3.55 gears... seems like if I went to at least 4.10's I'd get more rotation in the lower RPM's...
Dave
Old Jul 6, 2006 | 05:25 PM
unrulee's Avatar
unrulee
Regarding the timing issue, could a person ask for a dizzy at a parts counter for a 1971 dist. for a whatever vehicle and end up with something that would work well for a late 70's era modded truck.
I've been pondering this, instead of having to tweak my stock dizzy (which I think is on the way out anyway) for my 265 Deh, headers, and 4 barrel. If I get a new one should I just ask for a 71 model? How well would it work for my setup?
Old Jul 6, 2006 | 07:07 PM
2classics's Avatar
2classics
the 71 is a points dist. If your alright with that you could probly do it.
Old Jul 6, 2006 | 07:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
Correct! The newer distributors are electronic with the DS-II system which works extremely well. Find someone that has a distributor machine and knows what they are doing to set up a distributor.
Old Jul 6, 2006 | 10:17 PM
unrulee's Avatar
unrulee
OOPS!!! yeah I should have thought of that. Good catch.
Old Jul 7, 2006 | 09:42 AM
Falcon67's Avatar
Falcon67
18 degress is not a lot. You;'ll need to limit total advance to keep from pinging. ANy of the Durasparks are OK, but a lot of them will feed 40 degrees into the motor so they will have to be tuned. It's a PITA doing it on the car, but it can be done.
Old Jul 8, 2006 | 10:17 AM
2classics's Avatar
2classics
Just a thought. Could you take the points parts out above the plate replace it with electronic but still keep the same springs and weights. You would not have a core any more but I have an extra dist. Not looking at them right now maybe this is a stupid question.
Old Jul 8, 2006 | 01:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
The distributors are different.
crsweet78
23
Mar 26, 2024 04:31 PM
Bigbruce
Sep 25, 2013 07:34 AM
nikwave
16
Aug 1, 2011 05:52 PM
Jodell
Mar 6, 2008 02:42 PM
dposey
Jun 27, 2003 06:15 PM
