1993 Explorer - oil problems
Old Jun 29, 2006 | 10:56 PM
fordchica's Avatar
fordchica
Red face 1993 Explorer - oil problems
I recently bought a used 1993 explorer (160,000 miles) and the person that I bought it from says that for the past several years, they've had to add oil every 1,000 miles. They had mechanics look at it and nobody can explain why it's eating so much oil (it's not leaking out). Has anyone heard or have experience with this?
This is my first post...so I apologize if this has already been discussed several times !!
Any input is appreciated !!
Old Jun 30, 2006 | 05:21 AM
marragtop's Avatar
marragtop
If it's not leaking, then it must either be going out the tailpipe or into the cooling system. Have they checked for signs of a blown head gasket? Also, check the PCV valve. With 160k having to add a qt every 1000 miles isn't the worst thing in the world, especially if it's not leaving spots or smoking real bad.
Old Jul 6, 2006 | 06:52 PM
MrSki's Avatar
MrSki
While I agree it's going somewhere...it really should be investigated. A qt/1000 miles is a lot to just disapear. Mine's got nearly 180K miles and it burns a little but only about 1/2 qt each 5K oil change - doesn't leak a drop.
Old Jul 6, 2006 | 07:01 PM
hadaford's Avatar
hadaford
Probably you need new valve stem seals. Not too hard to replace IMO.
Old Jul 7, 2006 | 01:08 AM
MrSki's Avatar
MrSki
A puff of blue smoke at start-up perhaps?
Old Jul 7, 2006 | 01:12 AM
Bdox's Avatar
Bdox
I would change the pcv valve first and see if there is an improvement. It's not like you are in big trouble.
Old Jul 8, 2006 | 10:53 PM
aquanaut20's Avatar
aquanaut20
Had one doing that and it was weeping oil into the lower intake manifold, fixed that and away went all the other vacuum and fluid leaks.... 2.5-3hrs to change out the valley gasket.
Old Jul 13, 2006 | 12:10 AM
fordchica's Avatar
fordchica
Thanks for all of the ideas, I will print these suggestions out. It's strange because previous owner took it to a Ford mechanic and they were scratching their heads. I'll post my findings. Thanks all !!!!
GoFastGreek
Apr 11, 2022 05:26 PM
satx78247
Jun 8, 2016 04:27 PM
SHOpar
6.7L Power Stroke Diesel
28
Nov 14, 2015 12:07 PM
kjgibson2
29
May 19, 2012 08:05 AM
cabledog77
Dec 28, 2011 09:14 AM
