OK... Wasn't the O2 sensor
Old Jun 29, 2006 | 04:40 PM
Leader's Avatar
Leader
Question OK... Wasn't the O2 sensor
Took my 97 into AutoZone & had the codes pulled. Was told O2 Sensor, drivers side, rear.
Bought & installed said sensor. Had computer reset. No check engine light for almost a whole hour.
Went back & had code pulled again... same thing.... 0141
Replaced it again, cleared computer.... same thing, check engine light is back on.
What else can it be?
Old Jun 29, 2006 | 11:28 PM
99ExpyProblems's Avatar
99ExpyProblems
check the forums, you'd do better that way.
Do a search for P0141 on the forums and read all the replies.
Rule #1- talk to a guy at Autozone for 30 minutes and you'll find out they know absolutely nothing. I worked in Advance Auto for 2 years as a Manager, and you have to hold those guys hands.
When I had that code, it was all of the hoses that attach to the PCV valve. I lifted them up while the truck was running, and you could hear the air being sucked around it. Taped them up, erased the codes, no more code. Replaced all of the hoses, and the job was done!
Old Jun 30, 2006 | 08:16 AM
projectSHO89's Avatar
projectSHO89
P0141
P0141 is set when the PCM detects an electrical fault related to the heater circuit of the downstream sensor on the PASSENGER side. It has nothing to do with vacuum leaks or PCV valves.
Inspect electrical connectors for faulty/damaged pins. Inspect wiring harness for possible damage.
Swap downstream sensors and see of the problem moves. If, after swapping sensors, the code changes to a P0161, you'll know the sensor's heater was defective.
Reset PCM between tests.
Steve
Old Jun 30, 2006 | 08:43 AM
Leader's Avatar
Leader
Thanks... noticed that I might have replaced the wrong one & was planning on doing the passenger side today.
Will post the results.
Old Jun 30, 2006 | 11:07 AM
Leader's Avatar
Leader
Can't seem to get the senser unplugged. If it was metal, I would spray it with PB Blaster .... anythuing I can use on this plastic plug to make it easier to undo ?Being on top of the transmition doesn't help either.
Old Jun 30, 2006 | 01:10 PM
gibsonj's Avatar
gibsonj
The sensor plug has a pressure clip on the connector that must be depressed before the two parts of the connector will separate. I agree its a pain since you can't see what you're doing---good planning again by the engineers. If you have the new sensor already, take a look at the connector to help see where the pressure clip is, and might help you feel it on the old one.
Old Jul 1, 2006 | 06:06 AM
Leader's Avatar
Leader
Yah I know about that release... I had it depressed. Plug is just dirty I would guess. It is just going to take more tuggin' to get it apart.
Old Jul 4, 2006 | 04:16 PM
Leader's Avatar
Leader
Why doesn't someone make a penitrating oil for plastic plugs that have been exposed to weather and road grime for 10 years?????
Old Jul 4, 2006 | 10:39 PM
99ExpyProblems
Steve
lol, sorry I meant P0171.
Old Jul 5, 2006 | 08:20 AM
projectSHO89
All that for the wrong code...
P0171 codes aren't usually sensor problems anyway. Usually, they're due to a vacuum or exhaust manifold leak that throws the sensor's readngs out of range.
Steve
Old Jul 5, 2006 | 10:00 AM
99ExpyProblems
Steve
That is correct, but at Autozone, that is usually what they tell you to replace. My first post explains the P0171, not P0141, I read his topic wrong. I am not the topic starter, (Leader is the topic starter) the other people have helped him just fine.
Old Jul 7, 2006 | 10:17 AM
dkoenig's Avatar
dkoenig
I aggree. Both times I have seen that code on my 00, it was vacuum.
Good luck
F150Terry
2009 - 2014 F150
Jul 17, 2019 10:50 PM
chris66
1983 - 2012 Ranger & B-Series
Jun 23, 2017 08:59 AM
96halfton
Nov 6, 2016 04:31 PM
churioz
Mar 8, 2012 03:09 PM
intruder34
Modular V10 (6.8l)
13
Sep 12, 2008 03:39 PM
