Eod4
Old Oct 22, 2012 | 10:15 AM
  #31
F250F250F250's Avatar
F250F250F250
We're all learning here, no need to dis yourself.
I have a shop manual, would an exploded view of the tranny help you?
Old Oct 22, 2012 | 12:44 PM
  #32
DDogbreath's Avatar
DDogbreath
It sure would, I contacted Transtar a couple weeks ago and they have been no help after I requested one.
Old Oct 22, 2012 | 12:46 PM
  #33
DDogbreath's Avatar
DDogbreath
Originally Posted by 96_F250_Deezal
wow, you revived a post from 2006 !
If you already have the transmission removed, you do not need remove the pump from the case to replace the seal. even if you do suspect there is some debris that fell in there, I doubt you will find it. a hammer and long thin screw driver should do the trick getting the old seal out, you might be able to get a seal removal tool in there.
Also, be aware if you choose to remove the front pump, you will need to replace the front pump gasket, the large o-ring that goes around the bump body and the washers that go on the bolts that hold the front pump. It is also recommended you use the 2 alignment pins when re-installing the pump to the case. you can do it with out the pins, but it makes things more difficult. (been there, got several T-shirts... )
If you choose to remove the pump, there are 2 threaded holes in the front pump, which are used in conjunction with threaded adapters and slide hammer(s)
once you get the seal changed and ready to install the front pump;
**Make sure you replace the front pump gasket and o-ring before you re-install the pump **
Lubricate the rubber o-ring with vaseline or transmission assembly lube
tighten the bolts in a criss-cross manner and torque to 18-23 Ftlbs
Your info was great!
Old Oct 22, 2012 | 12:55 PM
  #34
DDogbreath's Avatar
DDogbreath
Do you happen to know what the part is called I have replied to F250F250F250 about ? I am not quite used to this site yet. I thought I replied 2-weeks ago but don't see it here...
Old Oct 23, 2012 | 02:27 PM
  #35
F250F250F250
Apologies for the (lack of) quality.. but here is a close-up of the front end of an E4OD.
Item 41 is a pump thrust washer, and item 44 is the pump gasket.
And here is the next section back.
Old Oct 24, 2012 | 01:08 AM
  #36
DDogbreath's Avatar
DDogbreath
It must be the thrust washer, I'll look for a better picture of one and let you know.
When putting it in drive (especially cold) you did not have to put your foot on the brake. It still felt like neutral but would go when you gave it the gas. It did not seem to slip other than cold start. It up shifted well. I'm wondering if The wrong part was installed? Or could it be something from further in that broke?
EDIT: Could it have been protection for the Needle bearing that someone forgot to remove?
Thanks for your help.
Old Oct 24, 2012 | 05:13 AM
  #37
F250F250F250
I added readable numbers to the pictures.
The parts listed directly behind the pump are:
41 - Washer - Pump Thrust (7D014)
42 - Needle Bearing Assy (7E486)
43 - Seal Ring - Teflon 2 Pcs (7G402)
44 - Gasket Pump (7A136)
50 - Coast Clutch Cylinder Assy (7G387)
bhesse
Jul 17, 2015 01:13 PM
irhunter
Jun 16, 2015 04:52 PM
Newtoford96
May 29, 2015 08:34 PM
Eric Kropp
Jul 21, 2014 02:33 PM
casweco
Jan 24, 2013 06:48 PM
