Alignment Help
Old Jun 29, 2006 | 06:27 AM
JSKI's Avatar
JSKI
Alignment Help
Can Anybody Let Me Know If I Need To Purchase An Alignment "kit" For My 2000 S.d.?? I Heard I Need To Get One If The Truck Has Never Been Aligned.....
Old Jun 29, 2006 | 06:45 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
No, I have never heard of such a thing. Sounds like someone out to make a few bucks.
Old Jun 29, 2006 | 06:58 AM
missouguy's Avatar
missouguy
A good shop will have all the doodads they will need. The Fords usually just need the tow set unless it has been in a wreck or something.
Frank
Old Jun 29, 2006 | 07:17 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
On the '93 4x4 super duty I use to have, It had non-adjustable camber bushings in it. And when it needed the camber adjusted I had to buy the adjustable ones the alignment shop had, this could be what they mean by "kit" .
I'm not sure if the '99 and up super dutys use the same style of bushing or not.
Old Jun 29, 2006 | 07:31 AM
mueckster's Avatar
mueckster
If adjustment is necessary, you would need the adjustable or correct degree bushings installed at alignment to reset the camber and caster. Shouldn't need them if the alignment was good from the factory and there has been no damage, modifications, or parts replaced on the front axle.
Old Jun 30, 2006 | 12:48 PM
79CEEJAY's Avatar
79CEEJAY
You may need a camber bushing. These are available in adjustable and non adjustable. Since the camber and caster is set through these bushings, sometimes you need to install the adjustable to get the correct settings. You also need to check the shop and get a print out on your alignment to make sure it is in spec. Most cut rate "cheap" alignments only consist of a toe adjustment. Remember toe in and camber are tire wearing adjustments whereas caster is NOT. A caster adjustment that is off will just make the truck pull and will not affect tire wear. And by the way, every time you turn the wheels on your truck you are wearing out the front end parts. This will cause your alignment to slowly fall out of spec. Also, I have rarely seen a truck out of thje factory "perfectly" aligned....it may be in spec, but not always "perfect".
Hope this helps.
