GAs gauge problem
Old Jun 28, 2006 | 04:38 PM
CLA4JC's Avatar
CLA4JC
GAs gauge problem
Ok, this is my first post. Thanks for all the info ya'll already have posted. I have a 84 f150. The gas gauge doesn't work properly. When I fill the tank it says its full, but within a few miles it drops to empty. Has any one had this problem or have a clue how to fix it.
Old Jun 28, 2006 | 06:22 PM
srercrcr's Avatar
srercrcr
If you want to spend some $$, then do some searches...lots written.
If you want the permanent fix route with no cost, fill up every 300 miles.
Old Jun 28, 2006 | 10:09 PM
GOTH_TRUCKER's Avatar
GOTH_TRUCKER
imo,its ur sending unit gaurenteed
Old Jun 29, 2006 | 08:09 AM
fellro86's Avatar
fellro86
DEfinitely sounds like snding unit, to buy a factory type replacement, it will run you between $80-120. Check some of the sponsors like Blue Oval Truck Parts and Jeff's Bronco Graveyard, they have them. If you have a pump in the tank, (injected or 460) that is your best option, if not, check out my gallery for the universal senders I put in mine.
