Aerostar Ford Aerostar
Slow turn signal blinking
Old Jun 28, 2006 | 10:30 AM
cookkd's Avatar
cookkd
What could cause my turn signals to flash slow?
When I origially got the van there was a broken wire to the passenger side front signal. I repaired that, and the signals worked, but flashed really slow, like 2 to 3 seconds between flashes. I installed a heavy duty flasher, which increased the speed, but it still is a lot slower than my other vehicles. Any suggestions as to what to look at?
Old Jun 28, 2006 | 11:39 AM
Pablo-UA's Avatar
Pablo-UA
If the resistance of bulbs is too low, flashes blink slow, but may be you wires are short to gound, check them with VOM removing bulbs. The second advice: try to see what is the summary bulbs power, try to calculate its resistance (I belive Ohm's formula is well known by you) and compare the result of calculations with the figures, that VOM reads. The next hypotesa relay is not well grounded.
Javie Aguilar
Sep 14, 2021 06:43 AM
SeaCarr
All Things Towing
Aug 8, 2016 03:43 PM
Big Big Blue
Jan 15, 2015 07:56 PM
deficientblair
2004 - 2008 F150
Dec 19, 2009 01:07 AM
thedoctor
May 13, 2009 06:04 PM
