Sponsored by: Auxito
Leaf springs
Old Jun 28, 2006 | 06:22 AM
Rick32's Avatar
Rick32
Leaf springs
On my 1998 f-150 my bottom leafs on both sides seem to have shifted sideways about half the width of the leaf itself should i be conserned> I am in the process of remodeling a room in the house and need to haul the old lath and plaster away. a lot of weight. i drove to work today with it loaded (not full) seemed heavy but not squirrly should i try to reset them a little advise would be appreciated thanks Rick
Old Jun 28, 2006 | 09:14 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
I would be worried. Something is not right. Not sure if you can reset/recenter them.
Would hate to be driving the truck when/if they let go.
Ed
Old Jun 28, 2006 | 10:13 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Myne did the same thing, im not sure why but they havent gave me any trouble for almost 4 years now. I dont haul a ton of crap but i have been known to some random heavy crap with no problem.
Old Jun 28, 2006 | 10:21 AM
Rick32's Avatar
Rick32
would it help to realign them and tighten the u bolts?
Old Jun 28, 2006 | 10:28 AM
Bdox's Avatar
Bdox
I would. Loosen the u-bolts enough so you can move them easily, check to see if there is anything broken, missing plastic parts or pins.
Old Jun 28, 2006 | 10:38 AM
BURNSTOUGHFORD
if your going to loosen your u bolts you might as well replace them, because they are more vulnerable to breaking once you remove the pressure on them. But thats just somthing i have heard time and time again, never actually had them break.
Old Jun 28, 2006 | 10:53 AM
Bdox's Avatar
Bdox
It is important to clean the threads well and and retorque to specs. I think the breakage factor is from people who tighten them down as tight as they can get them and then give them one more turn.
Old Jun 28, 2006 | 11:51 AM
Forddieselweasel's Avatar
Forddieselweasel
fell asleep one morning going down a road in my 92 and creemed into and out of a ditch and the only thing that happened was the rear leafs were like that buy more like an inch out, didnt noticed any handling problems, but now that i think about it i left a trailer atached over night and the next morning it rear axel was on the bumpstops, so it might just give you some over load prootection
