Aerostar Ford Aerostar
Low power?
Old Jun 28, 2006 | 02:49 AM
68Mercury250Ranger's Avatar
68Mercury250Ranger
Red face Low power?
Monday I took my Aerostar into a trusted tranny place for (I'm a truck/coach mechanic) service/inspection/adjustments. The guy incharge took it for a roadtest and said everything was working fine and I should wait to get it serviced until after I fix the "low power problem". I had thought it was a problem with the trans. It gets into just a small grade and it slows down drastically and won't downshift until you floor it. It just past a dyno etest and was very clean on emmissions output. I checked plugs/wires, and they are very clean. Air filter looks fine, I just put on a new fuel filter. What should fuel pressures be and when?
It is a 1993 3.0 A4LD and has the 3.73 ratio 7.5" axle, Could a vacuum leak cause low fuel pressures? Sorry some of these questions may sound dumb but I've been fixing Diesels for years and have lost all my Gas brains!
Thanks For all the help!
Old Jun 28, 2006 | 04:08 AM
TrickStyle3L's Avatar
TrickStyle3L
Exclamation Answers
Yes, the vacuum controls the Fuel Pressure Regulator which should be 40-45 PSI
the vacuum also partly controls the A4LD's shift behavior.
Your vacuum should be at 15lbs @ idle
Old Jun 28, 2006 | 06:56 AM
96_4wdr's Avatar
96_4wdr
pull ECU codes and please post to forum....some codes do not set a CEL
what is your gas mileage? indicates engine efficiency....
what is condition of ATF and how many miles since changed? how old is vacuum modulator on tranny? check for ATF dripping out of vacuum line on vac. mod.....is there full vacuum applied to vac. mod? any breaks, kinks, leaks or closures in vac. line to mod.?
the torque converter lockup and 3-4 upshift/downshift are controlled by the ECU....can be affected by failing throttle position sensor, failing O2 sensor, failing ECT, IAT or contaminated MAF
when was MAF and O2 sensors last serviced/changed? both have a major effect on engine power/mileage...clean emissions test does not list engine horsepower peak....
Old Jun 28, 2006 | 11:44 AM
Pablo-UA's Avatar
Pablo-UA
Theoretically vacuum leak may cause low fuel pressures, but if I have vacuum leak, I heve fast idle! Try to disconnect vacc.hose from the fuel regulator and check pressure again!
If fuel pressure is not good ore increases ufter key on slow, check fuel filters (one is under the van, the other is in the tank), and check fuel pump!
If fuel pressure is OK, try to read OBD-II data at idle and 3000 RPM... and let me see results. I can see what is going on! May be MAF, may be O2 may be clogged cat.....
Old Jun 28, 2006 | 01:22 PM
ken1mod's Avatar
ken1mod
I had an o2 sensor destroyed by leaded fuel once and this caused a huge power loss. I believe it drives the mixture full rich.
Ken
Old Jun 29, 2006 | 11:48 PM
Bear River's Avatar
Bear River
Former ******
Ok, since you have low power, try a full tune up.
brushwolf
General Diesel Discussion
Apr 1, 2013 06:36 PM
Matthew521
1978 - 1996 Big Bronco
Mar 6, 2012 08:03 PM
Matthew521
Mar 6, 2012 02:13 AM
Motsch788
Sep 27, 2011 01:31 PM
mark_fussell
Sep 18, 2010 02:04 PM
