Towing Gears?
Old Jun 27, 2006 | 10:21 PM
MUSKRATT2's Avatar
MUSKRATT2
Towing Gears?
I have a 79 ford f-100 with a 302 ,c-4 automatic, 2.73 gears, 255/70r15 tires, big tranny cooler, new radiator, 4 barrell carburetor, headers,& dual exhaust. I use it to tow my 24 foot enclosed car trailer loaded with my race car & golf cart.I live in southern VA. and we have a lot of mountains to climb when we go racing. The speed limit around here is 65.The problem i've got is when i start to climb any hill at all it allmost dies. The truck is only used to tow my race car so whatever gear i put in it doesn't matter because i won't be worried about the gas mileage driving it everyday. Also when i make the gear change should i put a posi unit in there also? The question I'm asking is what gear should I put in it?
Old Jun 27, 2006 | 10:30 PM
jake00's Avatar
jake00
I'd say 4.10, but I dont know much about gearing, Just see alot of people needing more power towing putting them in
Old Jun 27, 2006 | 11:50 PM
Kwikkordead's Avatar
Kwikkordead
Yes, 4.10 would be good. If you want to spend a lot of money, you could go with 4.56 or 4.88's and get a US gear overdrive unit.
Old Jun 28, 2006 | 09:07 AM
westtntrucker's Avatar
westtntrucker
Try this link a gear ratio calculator
http://www.intercotire.com/site63.php
Old Jun 28, 2006 | 06:05 PM
andym's Avatar
andym
The problem with 4.10's and that tranny is that the RPMs are going to be really up there on the highway at a cruising speed of 65. The problem with 3.55's is that they may not give you enough power. Maybe 3.73's would be a good compromise.
Personally, I don't like running a truck engine at 3k down the highway.
Old Jun 28, 2006 | 07:57 PM
kermmydog's Avatar
kermmydog
Again you can advance the cam a few degrees beyond TDC and gain a fair amount of torque, which is what you want. I have a 460 C-6 with 3;55 gears I tow a 10,000# trailer and many said go with 4:10s, well advancing the cam 4 degrees past TDC had I of gone with 4:10s I would of been sorry. If I do ever change gears 3:73s would be the most I would want.
Old Jun 28, 2006 | 11:00 PM
Kwikkordead
Kermmydog you have to change your thinking when it comes to diesels. Cam timing does play a part, but not as much as with a gasser.
Plus I just got back from vacation pulling my 14,000 lb 5th wheel and was having a lot of fun going past a few gassers pulling smaller trailers up the hill.
The only trucks that could get around me were empty semi's.
Old Jul 1, 2006 | 08:54 AM
MUSKRATT2's Avatar
MUSKRATT2
I agree with andym i'm not much on running a motor at 3 grand all day long, but when it comes to climbing all the mountains all day long going to the track i'm debaiting on what the trade off would be. The chart that westtntrucker showed me says to use 4.10 with 29 inch tires. I guess it will be a decission that i'm going to have to make! the other question that I asked has never been discussed and that is should I also put some sort of posi unit in there when I make this gear change?
Old Jul 1, 2006 | 02:07 PM
aurgathor's Avatar
aurgathor
You could install a GV under or overdrive unit -- that would allow you to get good towing power on the hills while having good RPMs on flat land. It's not cheap, however.
Old Jul 2, 2006 | 07:30 AM
jowilker's Avatar
jowilker
In real time your engine is hitting the power band around 3000 rpms. My 352 hits it around 2800 and is pulling like one of them N&Ws you see running through your town.
Your truck is set up for crusing and not pulling with the gear that is in there now. It probably will take at least a 3.75 for your truck to be happy with the trailer.
Put an AOD in it, with the 4.10 and you could realise some cruse and have the ability to tow. IMHO
John
Old Jul 15, 2006 | 05:01 PM
pops_91710's Avatar
pops_91710
It depends on your tire diameter. I wouldn't go more than 3.50 on an F100 with a 302.
Joshing_Machine
Nov 18, 2013 03:12 PM
MUSKRATT2
Mar 12, 2009 01:28 PM
sawboy
Nov 28, 2007 09:43 PM
TigerDan
General Automotive Discussion
May 2, 2005 03:59 PM
RichF350V10
Modular V10 (6.8l)
Aug 15, 2002 07:31 PM
