Brain pickin' time!
Old Jul 14, 2006 | 06:11 AM
  #46
GreatNorthWoods's Avatar
GreatNorthWoods
Originally Posted by Bikewrench
Just for sh**s and giggles. Has anyone ever ran across a cross flow radiator that will fit? There is a marked improvement in cooling using a cross flow as opposed to the down flow. I wasn't sure that there would be enough room from side to side in the radiator cradle. Just a thought.
Bike
Bike,
Yes a crossflow would work. I have seen them mostly in trucks using a GM or other subframe where the original radiator support was not used. The problem is in finding one short enough to fit the radiator support. I had a brand new crossflow from a mid 80s Buick that I wanted to use but it was too wide to mount horizontally and too tall to mount vertically (I've seen them mounted both ways). If you could find a compact crossflow that would fit the confines of the radiator support it would work great. Crossflows have better circulation than down flow radiators.
Vern
Old Jul 14, 2006 | 02:11 PM
  #47
GreatNorthWoods
Originally Posted by 49willard
Vern, I guess I have the cxxxy sitting lowerethan you do by at least 1 1/2 inches. I set it as low as I could and still clear the Jag IFS and room for headers.
I went the other way and set mine as high as possible without having to re-work the floor. I wanted to use a mechanical fan and be able to drop the pan without pulling the engine. I also don't like looking into the engine compartment of one of these trucks and seeing the engine sitting really low. It just looks strange...
Vern
Old Jul 16, 2006 | 04:25 PM
  #48
49willard's Avatar
49willard
Vern
Vern,
It sounds like you have the cxxxy higher and further forward than I do, I did not have to do anything to my floor of the transmission cover either. I have not removed the pan but I think there is sufficient space above the Jag crossmember and rack to drop the pan. I will have to check it out.
Old Jul 17, 2006 | 08:56 AM
  #49
Bikewrench's Avatar
Bikewrench
Bike,
Vern
Vern,
I may just take a walk around the "yard" the next time I'm there just to see what is available. Maybe I can find something that will help everyone in the crossflow area. I'll let you know.
Bike
Old Jul 17, 2006 | 02:03 PM
  #50
GreatNorthWoods
Bike,
The one I have came out of an 86 Buick Century with V6/air so don't bother looking at any mid 80s Buicks...
Vern
