1999 F-250 SuperDuty 4x4:
Overdrive light starts flashing and truck comes out of overdrdrive. Then the transmission starts shifting "hard". Mechanic says codes are 1247 and 708. Any info?
I've seen TSB's about high resistance in the clutch solenoid body but they are for 2001-2002 trucks. Does this mean it has a bad ground?
Thanks Guzzle.
That turbo boost code....does that refer to the engine turbocharger?
Do these codes suggest an electrical problem in the trans or something uglier?
