Air Conditioning Temps
Old Jun 27, 2006 | 02:51 PM
BandBFord's Avatar
BandBFord
Guys,
My F150 S'Crew is three weeks old and before I take it into the dealer to have the AC checked out I wanted to see what you guys experience... The AC in my new truck doesn't feel as cold as my 92 (which has been converted to 134 but i haven't used a gauge on it yet)... so I bought a temp gauge to check the air temp at the vents... with the outside temp hovering in the 95-100 range everyday I am seeing 50 degrees when sitting in traffic and a best of 46-47 at speed is this typical? This morning at 4:30 the outside temp was 71 and the best temp at the vent was 45-46... I would expect low 40's?
Any input would be greatly appreciated before a trip to the service department!
Thanks in advance!
Old Jun 27, 2006 | 06:31 PM
sdetweil's Avatar
sdetweil
I haven't measured mine, but I would say it is warmer than I expect. I just converted our 91 jeep to 134a, and it is pulling 42 goin down the road. and feels a lot colder then the new truck.
Sam
Old Jun 27, 2006 | 07:26 PM
FTE Trigger's Avatar
FTE Trigger
I think the Svc Manual specs the "Max A/C" at blower level-2 should be 40 degrees. Also I remember quite a lenghty thread on a very similar topic quite a few months back. You may want to run a forum search. Good Luck!
Old Jun 27, 2006 | 08:37 PM
HL1967's Avatar
HL1967
My 06 Lariat does't exactly freeze the skin off a chicken either. My Lexus blows a good 5-10 degrees colder and the cold air is nearly instant after turning it on. My truck needs a few minutes before the air cools off enough to take it off the max setting. I think someone told me that most domestic car makers bid out the AC and the stereo year to year so there is little quality control. But I can't validate that info.
Old Jun 27, 2006 | 10:08 PM
xtrm1stang's Avatar
xtrm1stang
Your normal, If you can get 40 degrees below outside temp your ok, the new scroll type compressors just don't seem to pump as good at idle, but are more efficient and have less drag
Old Jun 27, 2006 | 11:34 PM
krane operator's Avatar
krane operator
My 06 screw was the same, blowing somewhat cool not cold. Took it to dealer service man said it was normal, iTOLD HIM THAT ALL my other Fords(99 superduty,02taurus) were blowing colder than this high $ Lariat. I finally told him I wanted his AC tech to put the gauges on it and shure enough the ac tech said it was a couple of ounces low according to the specs of the truck. He discharged and recharged and checked for leaks for a total of 4 hrs. No leaks so ac man figured it came low charged from factory. Man now it blows colddddd.
Old Jun 28, 2006 | 04:45 AM
DJR 17's Avatar
DJR 17
Krane, I would have it checked again in a few months, you probably have a leak. The charge is weighed in so I doubt they screwed that up from the factory. Flexibe hoses and mechanical fittings are the toughest to keep from having an eventual slow leak. Does anyone know what the pressures should be on these trucks? Anyone have a charging chart?
Old Jun 28, 2006 | 05:31 AM
FTE Trigger
Old Jun 29, 2006 | 12:26 PM
WAS's Avatar
WAS
My 04 screw A/C was great. It used to freez me oput of the cab. It began to not work well. I took it to the dealer and they replaced the compressor. It now takes longer to cool and only gets to 50 when its 100 outside. Im about to take it back and have them look at it again.
Old Jun 29, 2006 | 03:27 PM
DJR 17's Avatar
DJR 17
Checked mine today, it got down to 41 with the outside temp at 92.
Old Jun 29, 2006 | 03:32 PM
WAS's Avatar
WAS
I just checked my A/C again. Outside temp according to the thermometer in the dash is 97 the A/C blows 50 at full blast and 40 one click under full blast. one thing I have noticed is that I don't here the compressor switch turning on and off all the time like it used to. Do you guys think this is acceptable or should it run cooler?
Old Jun 29, 2006 | 05:25 PM
NOTFASTENOUGH's Avatar
NOTFASTENOUGH
My 04 SCab blows a cool 23 at full blast and 97 degrees outside going down the highway. using a digital temp gun.
Old Jun 29, 2006 | 06:48 PM
WAS's Avatar
WAS
OK that tears it! I'm taking my truck back to the dealer. I live in the desert where it get over 100 every day in the summer. If NOTFASTENOUGH can get 23 degrees to come out of his vents then I would like at least 40 degrees when the fan is on full.
Old Jun 29, 2006 | 07:41 PM
4wdriver's Avatar
4wdriver
it was around 80 maybe more just the other day and my vent temp was also under 30 degrees
Old Jun 29, 2006 | 07:56 PM
tcparry's Avatar
tcparry
Checked mine today. Outside temp 85, vent temp was 36 .. Works great..
