Terry, it will. Would you post why you are considering the pedal change. When I upgraded my brakes on my 66 I kept the 66 pedal, and hooked it to the 76 assembly.
John
jowilker
Club FTE since 01 01
66 F100s
In the still cool hours of the night,
you can hear chevys rusting away.
the 65-72 pedal shaft, the unit that the pedal(s) attach to under the dash are interchangeable between these trucks. I removed the clutch pedal from my 66 and used a 72 automatic shaft with my 66 pedal for my automatic conversion. Pure painless swap. I think the 73-79 pedal shafts are slightly different, but I could be wrong..... I would try to find a 65-72 shaft, lots of them out there, at least for now..
[font size="1" color="#FF0000"]LAST EDITED ON 20-Jan-01 AT 10:40 PM (EST)[/font][p]I have a 67 F250, manual brakes, manual steering, manual tranny.
I love it. It drives like a truck.
Just a comment....
I did the swap in my 76 and simply replaced the clutch pedal w/ a bolt from an automatic donor,.... reusing my brakepedal. The clutch pedal on that had a long stud that went through the brakepedal hanger that is simply a bolt on the automatic versions. However.. My 79 truck (manual) has a completely different hanger assembly... the clutch and brake pedals are hung separately... I haven't studied the arrangement on my 69 w/ manual. So they aren't all necessarily the same. I'd go find an automatic of your year in the wrecking yard and have a look see. You might not need anything but a bolt
