Tunes(system)
Old Jun 26, 2006 | 06:14 PM
Alan D.'s Avatar
Alan D.
Exclamation Tunes(system)
I'm thinking of upgrading, New sounds for my redneck, hickville ride. here's the speakers. http://www.jcwhitney.com/autoparts/P...000380/c-10614 i have to order two sets of these, one set i'm gonna set into the under carraige, and make them aux. with a switch and water proof, besauce i do music at parties, and the other set, im gonna make as rear seats in the cab.
For speilen (playing in german) the tunes, im gonna use on of these. http://www.jcwhitney.com/autoparts/P...000283/c-10614.
the question is, what kind of battery should i use on my new system. i want to use the cd player, with the truck turned off for about 4 hrs, cranked. should i just use a heavy dudty marine battery and plug the regualr one in when i go, or should i upgrade the batter in the truck, and no change them.
P.s. i'm posting alot right now, because it's raining, and my girlfriend is at the shore, so i am inceribly bored.
Old Jun 26, 2006 | 06:24 PM
Alan D.'s Avatar
Alan D.
oh i forgot about this http://www.jcwhitney.com/autoparts/P...wflag-1#review
Old Jun 27, 2006 | 11:03 AM
RangerPilot's Avatar
RangerPilot
Look at Optima yellow-tops. They replace your stock battery and are much more capable for just general day to day running and running a system. I've never had problems with mine and it starts a lot easier than my old battery did, then again my old battery was too small for the truck (stupid previous owner).
RP
Zach
Old Jun 27, 2006 | 11:09 AM
Bob Ayers's Avatar
Bob Ayers
For what you want to do, use 2 batteries with a battery isolator, and you won't be stranded.
Old Jun 27, 2006 | 07:44 PM
FTE Trigger's Avatar
FTE Trigger
Thumbs up
I agree with Bob, the 2- battery system will make sure you're not left behind.
I'd also read the fine-print on the battery isolators. Most require (ask) that both batteries are the same to prevent "complications"... in a matter of speaking. I went with dual Optima Yellow tops while I had my Ranger. You on the other hand may not see the need to purchase the Yellow Tops, I had a few more things running in a more demanding cycle than a typical aftermarket sound system. But the Optimas never let me down.
Keep us posted during the new project!... Good Luck!
Old Jun 28, 2006 | 10:01 AM
Alan D.'s Avatar
Alan D.
Thanks, the double battery system sounds better than a single large battery. That what i'll do.
