1993 Coil Question
Old Jun 26, 2006 | 05:10 PM
plapczynski's Avatar
plapczynski
1993 Coil Question
I have a 1993 F150 - 300-6.
When replacing the coil (not the fender mounted, but engine mounted) I pulled the whole assy out using the bolts on the bottom.
What is the small cylindrical (looks like an old condensor would) that is also mounted on the same bracket as the coil?
Thanks.
Paul
Old Jun 26, 2006 | 05:16 PM
plapczynski
Here is a pic:
Old Jun 26, 2006 | 05:35 PM
pfogle's Avatar
pfogle
That is the noise supressor. It keeps unwanted pulses from being backfed into the electronic devices and causing noise. If you remove it it can cause interference in sensor inputs and radio noise.
