Heater Door HELP
Old Jun 26, 2006 | 04:59 PM
mopar's Avatar
mopar
Heater Door HELP
85 F-150 4 X4 heater. Door that controls Floor/Def & Panel has come off hinge or hinge has broken. Door operates between the two if you turn off engine, put fan on hi, temp on cold & A/C switch to off. Then start engine, slide A/C switch to Def. quickly, then it will switch to Def. You can put it to panel anytime. How much trouble is it to get to this door. I think the heater box is two piece. Can the bottom be removed? This is my daily driver. Haven't had a chance to look at it. (Working 16 hours a day, 6 days a week). Any one worked on heater box??????????????????
Old Jun 26, 2006 | 05:21 PM
travisd's Avatar
travisd
On my '84 F-150 2wd, it wasn't too bad. I removed the whole dash and split the box and replaced the door/hinge assembly, bought it from the local Ford dealer for something like $20 or $30. If you take your time and have some patience, it's a fun project. Sure is nice when it works correctly.
Old Jul 6, 2006 | 03:01 PM
mopar's Avatar
mopar
Will the heater box come out bottom of dash, or do you have to remove dash????????
Old Jul 7, 2006 | 03:59 AM
sharpster68's Avatar
sharpster68
I took a couple of small brass hinges and bolted them on to fix mine wasnt too awful hard and really didnt take too much time I did mine with the dash inplace. its been working for about 3 years now.
Old Jul 27, 2006 | 03:28 PM
mopar's Avatar
mopar
Thanks!!!!
