Oil PAN, got a question
Old Jul 26, 2006 | 06:22 PM
84tealbeast's Avatar
84tealbeast
okay i have a 84 f150 with a 302, do all 302's have two drain plugs????, im gonna get a new oil pan soon cuz the drain plug doesnt fit, i guess the last person messed it up some how, so idk. but anyway just wonderin if i have the right oil pan.
Old Jul 26, 2006 | 06:33 PM
smallblock351w's Avatar
smallblock351w
everyone ive ever seen in a truck has one drain plug. have seen cars with 2 drain plugs on in the back and on towards the front of the pan
Old Jul 26, 2006 | 06:55 PM
84tealbeast
yea i have one in the back adn it points straight down, then thiers one in the front like right above the cross member. anyone know a website that sells oil pans for our trucks or wut have ya.
Old Jul 26, 2006 | 06:57 PM
Mil1ion's Avatar
Mil1ion
Just Ford Motorsports chrome ones.
Old Jul 26, 2006 | 07:07 PM
John2Thomas's Avatar
John2Thomas
my 86 f150 w/302 only had a single drain.
Old Jul 26, 2006 | 07:32 PM
smallblock351w
i got mine right from ford when i needed one because i was going from a 302 to a 351w
Old Jul 27, 2006 | 12:12 AM
Sycostang67's Avatar
Sycostang67
You know they sell oversized and double oversized drain plugs. If your hole gets stripped out, you should be able to put one of those in the pan. If you have the DO, and it's too small, then you have a problem. I ended up removing my oil pan, and welding on a nut that I could thread a drain plug into. Works pretty good, and only cost me a few cents for the nut.
Old Jul 27, 2006 | 12:56 PM
82F100SWB's Avatar
82F100SWB
You have a double sump car oil pan in your truck, probably because your truck had an engine swapped into it from at car at some point in time.
If you swap to a regular rear sump pan, you may need to change the pickup tube also.
Old Jul 27, 2006 | 04:07 PM
84tealbeast
so what car do you think this pan came off, a mustang??, if so, just buy a mustang oil pan, i wanna put a new gasket on this pan, but i dotn know which car or truck to order a gasket for a oil pan from. so idk.
