1978 - 1996 Big Bronco
Servicing transfer case
Old Jun 26, 2006 | 04:11 PM
FLEALAMI's Avatar
FLEALAMI
Did the search but can't come up with anything conclusive. A clymer's manual tells me I should use Dexron II ATF to service the transfer case, the guys at the NAPA tell me it's gear oil. The owner's manual isn't clear, seems to indicate ATF.
Which is it? Do the tranny and transfer case share the same fluid?
For you old guys, like Vinnie Barbarino used to say, "I'm so confused!"
Thanks in advance,
Flea
Old Jun 26, 2006 | 04:44 PM
MBBFord's Avatar
MBBFord
I don't know why when you say you want oil for your transfer case everyone says gear oil....
It depends what year truck you have, and what transfer case you have, but more than likely you don't need more than 50W motor oil(non detergent), but it could very well be ATF.
Old Jun 26, 2006 | 05:56 PM
andym's Avatar
andym
Depends on the year, but most Broncos have t-cases that use ATF.
Old Jun 26, 2006 | 06:51 PM
FLEALAMI's Avatar
FLEALAMI
Sorry, it's a 1989 Bronco.
Flea
Old Jun 26, 2006 | 07:07 PM
dwoodler's Avatar
dwoodler
Your 89 will take Dextron III - I have the same year. It's a BW1356 T-case right? Gear oil is too thick and your pump won't move it, then the pump will seize and your t-case will grenade.....
Besides, my Haynes book says Dextron III!
Old Jun 26, 2006 | 07:59 PM
FLEALAMI's Avatar
FLEALAMI
I'm returning the gear lube and getting the Dextron III.
Thanks ,
Flea
