Need a Flywheel part #
Old Jun 26, 2006 | 01:50 PM
Ford.Freak's Avatar
Ford.Freak
I am having some difficulty finding the correct flywheel for my truck. The motor was a 351m that had lost the rear main seal. This took out the clutch. I was going to rebuild it but instead bought a 400 off E-bay. I bought a fancy Centerforce clutch ( Dual-Friction) but it has a large bolt circle to bolt to. I checked the part # for my flywheel, and I needed either a D7TE-6375A or a D7TE-6375B, this is according to Bubbas' M Workshop. The Part # that I removed from the original 351M has the part # D7TE-6380. The clutch set I removed was a 12 inch disc with a small patterned Long style pressure plate. I need to know which flywheel I need to bolt on so my clutch set will work. The spacing is in a large circular pattern. Any help would be appreciated as I have been through 4 clutch sets so far and none will bolt to my old flywheel, and I can't find a flywheel that will accept the big clutch, which I would prefer to use but, at this point I just want to use my truck, it has been 2 years so far. I also have a goofy three speed in the truck. It is geared very high, but that is a whole other issue.
Old Jun 26, 2006 | 01:57 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
You mention part numbers.
Please be aware
Part casting numbers are different than Ford Part numbers.
Have you checked with any of the Ford part web sites ?
How about FTE sponsor sites.
www.rockauto.com is good place for a part search
This is also more of a specific drivetrain question than a 73-79 truck question.
There are guys in the drvetrain forum that do swaps all the time , maybe post in there as well.
Btw, No need for blue or a change of font.
Some FTE people have difficulty with some Fonts,type & colours.
Maybe just use the FTE default system like most people do ?
