[font size="1" color="#FF0000"]LAST EDITED ON 29-Nov-00 AT 10:26 PM (EST)[/font][p]I what to drop my 72 f100 anyone have any recommendations on which beams to use.I'm using DJM spring perch and shackles in rear.
Al that is a great question for the Suspension Tires & Wheels Forumn. Would you see if you can get help there. That one was set up for your question and to releive the load here.
Most guys here don't care for lowering trucks.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
[font size="1" color="#FF0000"]LAST EDITED ON 29-Nov-00 AT 10:47 PM (EST)[/font][p]TruckTV just did a special on the drop and conversion of a 66 F-100 this last weekend. It was a re-run but still pretty interesting. Their web site is trucktv.com . its a pretty good website but could be a lot better. I imagine that the swap would be about the same.
"If you aren't living on the edge, you are taking up too much space"
Hootie65
Bigal72, We have been having so much fun with this subject lately. Read the posts from about a month ago on this subject. There are several manufacturers of dropped I Beams and some readers did have negative comments about a company in Arizona, (don't know the name). I personally would go with 60 series tires, maybe cut one coil, and flip the rear spring main leaf. What about this DJM perch and shackles?
William in Atlanta
[font size="1" color="#FF0000"]LAST EDITED ON 30-Nov-00 AT 09:30 PM (EST)[/font][p]TNN "Trucks" program is going to show a re-run on dropping the axels on a 66 F-100 on November 30 @ 1:30 a.m.
Skip4274
4everFord
the folks at www.truckn.com offer a real great kit im using one on my 72 and its a compleate kit nicer than the one on trucks and a lot less. good luck
remember , you would have to get shortened coil springs along with the I-beams for the front ( unless yours are leafs, the de-arched).. try the cheap clamp on style spring compressors first , see if you can stand all the shock first
Shouldnt have to get shorter springs at least I didnt when I did mine. If you use the coil compressors it will mess up you alignment. the front tires will look like this / \.
I have a 1974 f100 short box with a 460. I used a djm kit front and rear. I used their round i-beams in the front with the stock spings and it works great. I do have to get different shocks for the rear because the stock ones bottom out if your towing
