Lower Ball joint replacement
Old Jun 26, 2006 | 11:21 AM
murph_splorer's Avatar
murph_splorer
I'm going to be replacing the upper and lower ball joints on my 97 Explorer 4.0 OHV 2wd. I have a good idea how to do the uppers, but I had a few questions about the lowers. I have read the ball joint tutorial with pictures in the F150 forum.
The service manuals I have say that the whole lower control arm must be replaced in order to replace the ball joints. In reading various post on this and other forums, I understand the lower can be pressed out and all the
parts stores sell just the replacement ball joints. All the accounts I read so far have delt with 4wd vehicles. Mine is only a 2wd, so I was wanting to know what I will need to disconnect/remove in order to press the ball joint
out since I don't have a driveshaft or ABS sensors to worry about. Will I need to remove the torsion arms and shock absorbers to do the replacement. Can a floor jack simply be used to hold the lower control arm once the joint is disconnected from the lower? If anyone could enlighten me, it would be much appreciated.
Thanks.
jhurd12
Jul 16, 2008 02:48 PM
eallanboggs
Feb 23, 2008 09:41 PM
oldstylefseries
1997 - 2003 F150
Sep 26, 2006 09:38 AM
keithi71
1983 - 2012 Ranger & B-Series
Aug 23, 2005 07:20 PM
89 bronco II
Oct 6, 2004 08:30 PM
