OH OH!! Somethings a miss!!
Ok guys here it goes. My truck has smoking pretty good when i start first thing in the morning. Oil smoke i'm sure but would stop after a couple of minutes. I think its the injector o-rings. Well last night on the way home the truck started to buck and fart and smoking real bad!! i started the truck this morning to see what happens. It started but is smoking bad! When i try to rev it up it sounds like it missing on a cylinder and smokes so bad its not funny!! Do you guys think its the injector o-rings to? Please let me know what you think. Thanks in advance Lancer!!!
P.S. The cooling sytem is fine. Its not the head gasket!
Its a 99.5
Its a 99.5
Probably... If it was just smoking, it might also be a turbo seal, but since its running like poo, it's probably injector rings. Especialy if it's higher mileage.
Not an extremely hard job, just time-consuming.
While you tearing everything apart, you can check the turbo bearings and wheel, and the valve cover gasket and UVC wiring.
Well i spent 4 hours today redoing the o-rings on my injectors and all is well now!!! Not as bad as i thought it would be. O-rings cost me just over $200.00 and doing the work myself saved me alot of money!!!! Just thought i'd let ya's know what happened.
P.S. Checked my ccv canister today and it had about a quart of oil in it!!!
