Big cam
Old Jun 24, 2006 | 09:08 PM
rmalottwtes30's Avatar
rmalottwtes30
Big cam
What is the biggest cam I can get for my truck with everything else being stock? Its a 76 ford inline.
Old Jun 24, 2006 | 09:11 PM
rmalottwtes30
OOPS sorry I forgot which forum I was in. Can we get it moved? Thanks
Old Jun 26, 2006 | 06:38 PM
83Van's Avatar
83Van
Melling makes a mild towing/ RV cam for the 300 that should work with stock springs & retainers no problem. Isky has one that's a step hotter, a 248 with .415" of lift, which is big as you can go /w stock parts. First problem you usually run into with a hotter than stock cam will be coil bind on the exhaust valve springs. If your engine has rotators on the exhaust valves this reduces the installed spring height and the amount of total lift you can get before binding.
ptboi94
May 19, 2011 09:20 PM
Shernius
Mar 3, 2005 08:26 AM
myst
Jan 26, 2003 11:53 AM
BroncoScott
1978 - 1996 Big Bronco
Nov 20, 2002 12:56 AM
broom
Nov 24, 2001 12:46 PM
