Hey guys...not to repeat past chats...but I'm new here...spent 3 hours on the Search and didn't come up with anything specific.
We have a 2004 Expy 5.4 XLT Sport with the tow package. Think I read somewhere it is good for just about 9,000 lbs towing (rated highway). Anyhow...thinking of buying a 25' Alumalite Holiday Rambler Travel Trailer. GVWR on the trailer is 8,000lbs. Unloaded weight of the trailer is 5,630. Just to save some weight, I'll probably tow with it 1/2 to less than 1/2 full of fluids.
What I would like to know in everyone's experiences here, is what kind of mileage I can expect. Traveling 70mph unloaded, reciprocating around 2100-2200rpm we get around 17.5mpg. We will be driving I-70 and I-15 from Monument, CO to Southern CA and back, so lots of hills, and high altitude.
Any thoughts on this? It's a 2300 mile round trip, so I want to do it right.
Thanks everyone, and :flipoff: to the new guy I guess! LOL
I have a 2003 Expy XLT 4x4 with a 5.4 and tow a 6500 lb travel trailer. I'd suggest the following things:
Sway Control. The rear on these rigs likes moving, and a sway control fixed mine.
Better tires. After the first time I towed, I got rid of the "car" tires and put on BFG All Terrain TA's that are load range D. The isdewalls are stiffer, resulting in, again, less sway.
A cold air intake and a catback exhaust. These really helped mine. I used a MAC CAI and a Gibson catback. I can pull hills much easier now.
Make sure the weight distribution hitch is set correctly. You want the truck and trailer to be level when connected.
Synthetic fluids. Engine oil, trans fluid, and differential. I use Royal Purple all thru and it helped somewhat.
For gas mileage, well, with my trailer, at 55-60 mph, in mixed terrain (flats, Sierra Nevadas on I-80) I get about 10 or so. On just the flats, maybe 11.
Hope this helps.
I have a 97 Expy with a 5.4L and pull a 30' camper all the time with it. It pulls it great but the gas mileage sucks at 6mpg. Just bought a 99 Expy with the 4.6L and it handles the camper great but its a bit more strain on the engine pulling the camper. Gas mileage was around 7mpg not much better. I do not keep the tanks on the camper empty and usually load up the camper pretty good with bikes, etc. I was advised to pull it next time with the Overdrive turned off. Have not done so yet.
If you are buying new, suggest you look inside at the federal "as shipped" weight, not the brochure weight. It will be inside a cabinet door near the stove/fridge. Does this trailer have a slide? At 25', probably not. My '03 does not do well towing more than about 6000lbs, and I had to put Michelins CrossTerrains to counter sway. The Continental tires were too soft and didn't have the psi rating to run at 45 pounds.
Consider getting a Reese Dual Cam or an Equa-L-Izer hitch--stay away from the friction add-on sway bars. Or, if money is no object, get a Hensley Arrow hitch-no sway with it.
Alumalites are good trailers, just set it up right and enjoy the camping.
The Expy is weak on stopping power if you tow anywhere near the weight limit--panic stops will age you in a hurry.
I tow my 23' boat with my 5.4L Expy with no problems. Dual axle and get about 12MPG between Vegas and SoCal. You will HATE those hills(And Semi's) in that stretch of road.
One tip on the brakes: The rears are fine, but I switched to a slotted set of Power Slot rotors and Hawk Ferro Carbon pads. What a difference! Plus they are quiet and grab hard when you need them to!
I always thought OD off while pulling was a mandatory thing. Gets the RPMs up a bit, but driving slower is much easier on the trans anyhow. I can't imagine it is that much better on mileage however.
Buying used, and that is the info on the tag. I had the guy send me a picture of it. I haven't looked at any specific hitch yet, except for the Easy Rider Air hitch...expensive! Don't know how much better they are though. I'll check out the Hensley Arrow next, as I have heard about them.
Have a great trip!
Those hills are nothing when compared to pulling through Vail and the Loveland Pass in CO. If I hate those, I'm going to be really hating life there. Thanks for the tip on the brakes...amazing, I had the same setup on a VW Golf TDI and man, what a difference. Used to be able to lock into the ABS at 65mph on High Perf tires.
Guess I'll be looking at tires as well then! Those Conti's are pretty soft.
Towing with the OD off or on shouldn't have much of an effect overall. The trans is smart enough to know when OD can't be used. However, if you are on a level run, it is possible to use OD, but cost mileage. Sometimes, the rpms put you in a better torque range with Dr using less pedal, than OD using a lot of pedal. I think, tho, that you would need to drop the overall speed when using Dr. This usually comes into play if you are towing near the max weight rating.
very very true...and totally agreed. I'm thinking of trans longevity too, as I know nothing is worse for an auto trans than hunting for a gear.
On that note...maybe a bad mileage, slow towing experience will help talk my way into a diesel pickup. I know it isn't Ford...but I was and am seriously considering a Mega Cab Cummins Ram. We would need the space, as I'm about to have 3 kids in car seats. This would be a great "sales tool" for my wife. <evil grin>
Diesel Excursion...or Mega Cab CTD Ram. Oh bother...what to do. Or is the V10 Excursion every bit a tow horse as the Diesel? I probably won't be using more than 10 times a year to tow anything heavy.
What kind of mileage do those Excursions see? I do prefer the Ford interiors if nothing else. Also, do the Excursions use solid axles? I ask because, one, a smaller trailer won't do. I'm about to be papa to 3, and I will also need room for 3 car seats! D'OH! What a joy to be a dad!!!!
Also, I ask about axles, because we are adventurous types. I'm not hard core 4x4...but it would be nice to not get stuck on a safari!
The big block gassers are gas hogs no matter the make but great tow beasts.
The Diesel Excursion is much more effecient if you can handle the noise and the maintenence schedule. It will last forever. I hear of 20 mpg unloaded and 10 mpg towin 3-4 tons. Because the Excursion is on the Super Duty 250 chassis it is solid axle front and rear (complete opposite of an Expedition).
The "X" is very sought after by the big travel trailer crowd. With your reproductive activity, you may want to consider an E350 Diesel 12 passenger Club Wagon.
BTW - what is your gear ratio?? Look on the drive door jamb for the axle code on the sticker. Hopefully I6 or L6
Also, there are many ultralight bunkhouse travel trailers that will work behind your Expy, don't hang your hat on the first one you see.
My travel trailer is a 26 footer two bunks and queen bed. Weighs 4500 lbs going down the road. Look for bunkhouses with rear slides. You'll have four up front usually and a queen in the rear. Frontier, Surveyor and Outback are three that come to mind. TrailCruiser makes one too.
