Sponsored by: Auxito
02 4.6 EGR insufficient flow code
Old Jun 24, 2006 | 10:21 AM
stephen410's Avatar
stephen410
Unhappy 02 4.6 EGR insufficient flow code
I have replaced the EGR vale,DPFE, and removed the upper intake and cleaned the ports. I am STILL getting the code for insufficient flow. HELP!, I gotta get thisthing inspected!
Old Jun 24, 2006 | 05:52 PM
projectSHO89's Avatar
projectSHO89
Have you done any testing to actually diagnose the problem?
Old Jun 24, 2006 | 07:13 PM
stephen410's Avatar
stephen410
other than standard diagnostics check?...no. I've gone through the steps one at a time; cleasn egr, clean intake, change dpfe, change egr, etc..... I have gone to two different individuals to run checks; both the same.
Old Jun 24, 2006 | 11:40 PM
LxMan1's Avatar
LxMan1
What about the tube from the exhaust manifold to the EGR valve?
Old Jun 25, 2006 | 07:21 AM
stephen410's Avatar
stephen410
that I haven't tried yet. Is it an open shot to the exhaust? I'll try running a coathanger through it. Thanks, I'll let you know if that gets it.
Old Jun 25, 2006 | 01:25 PM
stephen410's Avatar
stephen410
tube and connector were clean and open all the way into exhaust manifold. double checked vacuum between egr and dpfe and it was good. any other suggestions would be helpful
TXE150
Jan 3, 2015 06:10 PM
blueharley
Mar 29, 2007 09:03 AM
ro2kee1
Dec 19, 2005 04:06 PM
fosterwc
1983 - 2012 Ranger & B-Series
20
Aug 25, 2005 06:33 PM
