"GOT CODES?"
Old Jun 23, 2006 | 06:37 PM
Hotwheelbill's Avatar
Hotwheelbill
"GOT CODES?"
Well I know that some will scold me for the speed, but it was 4 am on the way to work and all clear. At sometime over 100, I see a check engine light. Pull over, but I did not want to shut down right away. Got out and checked for fluids....none. Sat for 5 mins. and shut down. Scan with Super Chips and find 1)p0603 Internal ctrl Mod KAM Error. 2) p0743 Torque Converter Clutch Sys Electrical Failure. (may be my tran shif problem) 3) p0238 Turbo Boost Sensor A Circuit High Input. (over boost?).
It is the first one that scares me. Anyone know? BTW the check engine light went out by the time I got stopped.
Old Jun 23, 2006 | 06:45 PM
CAT_man_963's Avatar
CAT_man_963
The first one - 0603 - is pretty much normal for any truck with a tuner or chip - no worries.
The second - sorry no idea there...
The third - I THINK that would be the dreaded overboost/de-fuel code.... You need a regulator before your MAP sensor to keep that one away
Old Jun 23, 2006 | 06:53 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yep....that's it.
Old Jun 23, 2006 | 08:17 PM
Hotwheelbill
Great to hear! That "internal" word got to me a little. I do not think I need to fix the fuel problem, not something that I do often. Thanks for the info.
Old Jun 23, 2006 | 08:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
Right. It only happens when you exceed 24 psi boost pressure.
Old Jun 23, 2006 | 09:34 PM
nodakford's Avatar
nodakford
Accordingto the Ford Diagnosis manual "Check engine light illuminates when a fault is detected in second drive cycle(California, OBD II calibration)
Transmission Control Indicator Light(TCIL) flashes when fault is present.
