Jarred;
I realize that once I got to the middle of the post. Good luck with your truck. Check out my 59 in my gallery, has a 70's front 4x4 axle. I'm debating to return it to 2wd or keep it 4x4, with front disc brakes.
P.S. where is dora Ala?
Roll Tide Roll
Mitch
It looks better now because the passenger rear spring had a broken leaf so I replaced them with a set from a mid 70's F-100 and it sets up pretty high in the rearend
broken leaf springs. when i got my 59 the front leaf spring had been broken and welded back together. and it wasnt good welding either i got quite a laughf out of it. i think i have a pic of it in my gallery. sounds like your projects going good
sounds like your 59s coming along good while mine hasnt been touched in months but im finally get some of the bugs worked out of my 64 althogh it just bent another push rod that makes 15 now. well good luck with your truck
Hi out there! Can anyone tell me if my 1960 -100 Shortbed - Cab and Bed fit/mount onto a 1974 Ford F-250 4x4 Ranger Frame. Or can anyone suggest what 4x4 frames would fit? I'd really like to get this cab and bed onto another 4x4 frame without having to start fitting the gear onto the 60 frame.
we have got some of th frame and cab sandblasted. Today we bought 1000 lbs of blasting sand in 100 lb sacks and it was heavy. This should be enough to sandblast the rest of the truck
