Driveshaft question
Old Jun 23, 2006 | 09:12 AM
comochja's Avatar
comochja
Driveshaft question
I have replaced a 240/3m in a 66 SWB with a 360/C6 from a 76 LWB. Is there a direct bolt-in driveshaft available from a 70s SWB, or do I have to have one custom made?
Old Jun 23, 2006 | 09:22 AM
jowilker's Avatar
jowilker
I went to a one piece and had mine custom sized.
John
Old Jun 23, 2006 | 09:35 AM
banjopicker66's Avatar
banjopicker66
If the '76 had a single driveshaft, it can be shortened to fit your SWB very easily by a machine shop.
Old Jun 23, 2006 | 11:32 AM
comochja's Avatar
comochja
How should I measure it? I know some play is needed to install the rear UJ, should I put the yoke all the way in and allow 1 inch or so?
Old Jun 23, 2006 | 08:44 PM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
good question. Im curious about that too.
Old Jun 23, 2006 | 08:56 PM
banjopicker66
The yoke should have a witness line on it, from where it rubbed on the rear seal, or the rear bushing internal to the tailshaft housing.
I inserted the yoke to the witness line, and turned it so that the holes for the U-joint caps were parallel to the ground.
Then I measured from the outside of the transmission yoke to the inside curve of the differential yoke.
It fits perfectly, and I can fully load the truck with no bottoming out (because it is too long), nor have I lost a driveshaft bouncing over railroad tracks (because it is too short).
Old Jun 24, 2006 | 02:27 PM
William's Avatar
William
My drive shaft guy wanted the measurement from the center of the U-joint to the center of the U-joint. Came out perfect. 180 Bucks and that included a new yoke and two new joints. Talk to your driveline shop and provide the information they want.
rbmead
New Member Introductions
Nov 20, 2016 06:59 PM
cannonman
Aug 22, 2016 03:40 PM
dman24
Mar 24, 2015 04:21 PM
bbf150
Apr 9, 2013 09:02 PM
6t6merc
Jan 26, 2010 03:53 AM
