No brake/hazard lights
Old Jun 23, 2006 | 08:17 AM
oarhead61's Avatar
oarhead61
Well I figured out why my turn signal's weren't working. Apparently a loose connection in the steering column. Must've happened when I put in the lower actuator. 91 F150.....no brake lights, no rear hazards......everything else works. This truck has cruise control that I don't think works, I just put it on the road. Does my brake light situation have anything to do with the steering column?This truck is killin me!
Old Jun 24, 2006 | 05:23 PM
oarhead61's Avatar
oarhead61
Just for info purposes.........the brake lights/hazards are somehow tied into the turn signals in the column. When I changed out the actuator I apparently didn't tighten down the plastic piece enough so there was a bad connection somewhere. Tightened everything up and got everything working!
The truck is still killing me!
knash0727
Dec 23, 2014 11:15 AM
knash0727
Dec 23, 2014 08:01 AM
mike L
Electrical Systems/Wiring
Sep 14, 2014 06:56 PM
Mattoon Machine
Jan 20, 2014 07:10 PM
4fords
1997 - 2003 F150
May 8, 2008 09:03 AM
