Steering Gear Lubricant
Old May 12, 2001 | 11:20 AM
whomrig's Avatar
whomrig
Old May 15, 2001 | 02:27 PM
72stepside's Avatar
72stepside
I couldn't find what weight of gear oil to use in my steering gearbox. What should I use? Also, how does the screw and backing nut on the top of the box "tighten" the slack out of the box?
Old May 15, 2001 | 03:19 PM
whomrig's Avatar
whomrig
Hey 72, I have a 1960 F-350, and used 85W-90 gear oil in my steering box, but consult your shop manual to be sure. Also, on the steering box, loosen the locknut, and turn the adjusting screw either clockwise or counter clockwise a little at a time to adjust the "freeplay". This will move the sector shaft closer or farther from the worm gear to decrease/increase freeplay. hope this helps.
Wayne
http://home.pacbell.net/whomrig
Old May 15, 2001 | 03:46 PM
72stepside's Avatar
72stepside
Thanks for the reply. The reason I asked about the lubricant was because I could see a grease (tie rod end or king pin grease) substance in the box. I'll go with the 80w-90.
Thanks again
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
