79 pitman arm
Old Jun 22, 2006 | 10:54 PM
bloodhound51's Avatar
bloodhound51
79 pitman arm
where can i get a drop pitman arm for a 79 f-250, i put a 4 inch lift on it and i cant locate a pitman arm.
Old Jun 22, 2006 | 11:10 PM
unrulee's Avatar
unrulee
When went 4 inches on my 79 250 I used a Skyjacker adjustable drag link. $120 from Nat'l Tire and Wheel.
Old Jun 22, 2006 | 11:20 PM
frankalonge's Avatar
frankalonge
Assuming this is for the 4wd... Don't know if it applies to the 2wd.
I use a drop drag link that came with my Mickey Thompson suspension kit. It has replacable "tierod ends", so it takes care of two issues at once: worn stock drag link and the suspension drop.
Bronco Graveyard sells a drop pitman arm. Part number 22826.
edit: Bronco Graveyard also sells the superlift drop drag link. Part number 22980.
Old Jun 23, 2006 | 08:21 PM
bloodhound51
alright i found the skyjacker part i will look on bronco graveyard
yes it is 4wd
rollingthunder77
Feb 22, 2015 02:52 PM
lasthighboy
WTB - Parts & other
Jul 2, 2012 09:14 PM
7375highboy
Feb 3, 2011 02:12 PM
oldhalftons
Feb 20, 2005 01:01 AM
