Sputtering, rough idle, no power
Old Jun 22, 2006 | 08:16 PM
cbj1111's Avatar
cbj1111
Help!
2000 Excursion, 4x4, 7.3 PSD, 110,000 miles. Superchips - high perf setting.
Here are my symptoms:
Severe loping, no power, studdering.If it was a gas engine I would say it was a timing issue or possibly a mass airflow sensor.
Several weeks ago the wife went out to run an errand, on start up it loped several times then settled down and ran fine for several weeks.
Yesterday she calls me and tells me it won't start. I arrive to find it almost out of diesel (figures). I add 5 gallons to the tank by fuel can, just for good measure. It will start but has a bad "timing" issue and belches white smoke. I remove the superchips and set back to stock programing. I nurse it back to the house, by the time I arrive (5 miles) the truck will hardley run. No power at all, and barely idling. I have an inclined driveway and it barley made it up.
I have replaced the CPS less than 10,000 miles ago and the fuel filter less than 15,000 miles. Last month I had a water pump go bad on me and replaced it myself. ( I recommend getting the flywheel tool from Ford before starting this project!!).
Any thoughts??
Truck is sitting in the driveway awaiting your vast knowledge!
Thanks!!!
Old Jun 22, 2006 | 09:16 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Welcome to FTE cbj1111!
You'll find everything you need to know about your X and then some...
If you haven't done so, check out the "Read First" at the top at this and other forums.
As for your problem, not sure what to tell you, but what other mods do you have on your truck? (exhaust, intake, guages etc.)
Old Jun 22, 2006 | 10:33 PM
SSGG's Avatar
SSGG
With the tank down to E I would suggest checking the fuel filter again. Bound to have pushed the bottom sludge up.
Wes
Old Jun 23, 2006 | 09:56 PM
cumminpwr11's Avatar
cumminpwr11
do you have an obdII reader? if you had a chip on it or a tuner, it might have been put is "safety" or limp mode.
I will be honest, I am speaking off of cummins experiance.
1. borrow obd II scanner from autozone.. scan
2. Check lift pump and/or fuel pump.
3. hoffed turbo (siezed it)
4. like stated before, check fuel filter.
I hope that this gives you a few places to start.
keep us posted.
Chris
ps. if you have not posted this yet in the diesel forum. you should
Old Jun 26, 2006 | 06:16 PM
RTM's Avatar
RTM
It sounds like the cam position sensor is going bad. Pretty common on the 7.3
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
NUKFYRSQ
Aug 7, 2013 08:13 PM
Dan Thorpe
Jul 9, 2013 07:14 AM
ScottInTexas
17
Oct 1, 2007 04:22 PM
sm_pacman
1978 - 1996 Big Bronco
Apr 12, 2006 12:19 PM
