clutch help
Old Jun 21, 2006 | 01:15 PM
therigwelder's Avatar
therigwelder
clutch help
i purchased a 94 superduty turbo diesel about a month ago.the previous owner said he put a new clutch in the truck.the clutch master is brand new.
yesterday my pedal went to the floor i checked the master and it was low,i then crawled under the truck and looked at the slave and saw some fluid on the outside of the slave but couldnt tell if there was any leak i wiggled the slave and my pedal popped back up and it drove to the house fine .i got a new slave to put on but i cannot get it in.shouldnt there be some play in the fork to get the slave in?ive depressed the plunger on the slave as far as i can
i pulled the fork out and looked in the fork boot hole at the throwout, the bearing turns fine and it appears to slide on the shaft as well.the fingers on the pressure plate dont appear to be bent or anything.I relly need to get this truck back on the road,thanks
Old Jun 26, 2006 | 04:07 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved to clutch forum
Eallend7
Jan 13, 2013 07:16 PM
Shark Racer
52
Aug 17, 2010 08:35 PM
Bigcat350
25
Dec 10, 2009 07:23 AM
Boyd
Jun 29, 2005 03:24 PM
Tony G
Jul 15, 2004 01:35 AM
