Exhaust question
Old Jun 21, 2006 | 06:24 AM
unger316's Avatar
unger316
Exhaust question
Hello everyone, i'm new here and this is my question
I just bought a 87 F150 4x4 witha 302...the guy i bought removed the cats and mufflers and put glasspacks on and both pipes exit infront of the rear tire on the passenger side, my question is is this to free flowing for the engine, as in the engine not having enough back pressure, and is it bad for the engine, i've heard that its not going to harm anything, but i've also been told that my valves might burn up on my engine.
thanks, chris
Old Jun 21, 2006 | 06:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 21, 2006 | 07:08 AM
holland501's Avatar
holland501
Depending on where you live it might cause you some problems when it's time for inspection. But your valves are safe.
Old Jun 21, 2006 | 07:48 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
the old 'burn up the valves' trick is a wive's tale that people started when they ran without exhaust at all. They would be very hot, and then when you shut off the engine, cool air rushes in and shocks everything.
Emissions is your only real concern.
Ryan
Old Jun 22, 2006 | 12:48 AM
F-150_XL's Avatar
F-150_XL
No worries with hurting the engine, but it will sound a lot better if you put some sort of crossover or x-pipe on it to allow both sides to flow together. It will give you a much more even-toned sound. Just my 2 cents.
Old Jun 22, 2006 | 06:32 AM
unger316's Avatar
unger316
thanks for the input guys, i'm happy to know that i don't have to fix the exhaust right away, but yeah it will get some sort of dual exhasut system in the future. the truck does sound pretty mean with the glass packs.
Old Jun 22, 2006 | 09:16 AM
jimdandy's Avatar
jimdandy
Smile
Ryan
The burning of valves stems from carburated engines. If you put a free flowing exhaust on an engine with a carb, many times it would lean out the carb to the point that it would start burning the vallves especially if the carb was on the verge of running lean anyway. Later engines with computer control simply adjust the mixture to compensate. As for backpressure, it is caused by a restriction, and youdon't want any. The EGR dumps enough burned gas back in the intake without the exhaust system backing up more. jim d
bubba_3711
Apr 14, 2014 03:05 PM
midsouth
Jan 3, 2014 06:53 PM
chrisal1234
Feb 20, 2011 06:38 PM
Hillcapper
Jan 5, 2008 01:44 PM
meck1
1983 - 2012 Ranger & B-Series
Jul 21, 2007 09:26 PM
