Brake Booster
Old Jun 20, 2006 | 06:51 PM
wiltms's Avatar
wiltms
Brake Booster
Hello to all, I'm having a small problem with my brakes on my 2wd 85 F-150 with a 302 automatic. Basically when i hit the pedal it goes to the floor with no resistance until about an inch from the floorboard. When I don't have my foot on the pedal there is an air leak from around where the rod goes through the firewall. After all the searching I have done, it appears that I have a faulty brake booster, and I would like some input before I spend the $150ish on a new one with a new master cylinder as well. Just to throw another thought out there, could a master cylinder rebuild kit possibly fix this problem?
Thanks in advance,
Michael
Old Jun 20, 2006 | 08:07 PM
SuperSnake's Avatar
SuperSnake
I have to same problem with my F250.I called Oreillys for another power brake booster with a master cylinder.Mine leaks between the booster and mc and what I have been told the diaphragm ruptured.O'Reilly Auto Parts qouted a price $109.99 that was the cheapest I could find.
BTW Welcome to FTE,alot of nice people here and loads of info.
Old Jun 20, 2006 | 08:22 PM
wiltms's Avatar
wiltms
Thanks for the welcome, I've acually been around here for about 3-4 years now from the early days when I had my old 79 F-250 4x4 supercab. I just got my 85 about 3 months ago with 94,xxx miles on it for $1000 from the original owner. Anyway, I acually know how to use the search function so I don't repost the same thing as someone else, but this one stumped me a little and being military I try not to spend more money than I have to seeing I don't get that much anyway. Buy the way, we don't have an O'rieleys around here that I know of do they have a website you can order from that you know of? Shipping would probibly bring the cost up to about the same in the end though.
Old Jun 20, 2006 | 08:30 PM
SuperSnake's Avatar
SuperSnake
Don't know if they have online shopping yet, but their website is www.oreillyauto.com it can help locate parts and also store locations.
Hope you enjoy your truck and thanks for protecting the country.
Old Jun 20, 2006 | 08:35 PM
wiltms's Avatar
wiltms
You're welcome, and thank you I'll go check them out.
Old Jun 20, 2006 | 08:40 PM
wiltms's Avatar
wiltms
Well i just checked out there website and they have a sign that says online ordering coming soon, but thanks anyway.
Old Jun 21, 2006 | 12:22 AM
Piffery1's Avatar
Piffery1
Autozone has the master cylinder /booster online or in-store (special order):
CARDONE POWER BRAKE BOOSTER for a 1985 FORD TRUCK F150 1/2 TON P/U 2WD
Unit Price: $76.99
Core Value*: $38.00
Part No.: 50-9315
Weight: 17.65 lbs.
Warranty: LLT
Availability: Online: Special Order
Store: Special Order
Note:
I bought the heavy duty dual diaphram version for my F350 2 or 3 years ago and I'm very pleased with the quality and price.
Old Jun 21, 2006 | 01:22 AM
sierraben's Avatar
sierraben
I also have a leaky m/c; between the m/c and the booster.
This is going to be my third m/c-booster combo for my 81 F150.
Time to get a little dirty.
Old Jun 21, 2006 | 05:19 AM
jinserra's Avatar
jinserra
advance auto has a bendix reman for 77.00 w/ a 25.00 core charge.
Old Jun 21, 2006 | 09:17 AM
SuperSnake's Avatar
SuperSnake
I guess prices are set by the area you live in.O'reillys was the cheapest in my area.
Old Jun 24, 2006 | 03:04 PM
SuperSnake's Avatar
SuperSnake
Any luck Wiltms??
Old Jul 5, 2006 | 02:53 PM
wiltms's Avatar
wiltms
No nothing yet, had a family emergency and have ben gone for a little while. Either tonight or tommorro I will be going to autozone and picking up the parts. I think I'm just going to get the master cylindert/ booster combo and see how it works. I'll let you all know.
Old Jul 5, 2006 | 08:58 PM
Piffery1's Avatar
Piffery1
Be sure to "bleed it" on the bench (with master cylinder level horizontally) prior to installation so you get all the air out. Instructions with unit should provide details.
Old Jul 6, 2006 | 03:46 PM
wiltms's Avatar
wiltms
Thanks for the info, but i just picked up the one with-out the m/c so I don't have to fiddle withe the brake fluid at all. I also picked up the upper and lower ball joints, rear wheel bearings/seals and a center drag link. I have alot of fun ahead of me if it will ever stop raining here in Virginia.
400inatruck
Sep 5, 2012 09:50 PM
stephenok711
Jun 2, 2012 05:59 PM
dragonman
1978 - 1996 Big Bronco
Mar 12, 2010 07:24 AM
jsutton
May 2, 2005 08:29 AM
lsrjf
Nov 7, 2001 01:21 AM
