Quick Questions
Old Jun 20, 2006 | 04:44 PM
Rocky Mountain Jeff's Avatar
Rocky Mountain Jeff
Quick Questions
It is time to kill the buzzer if only I can find it. Seems I have the general area but I do not see it little lone feel it when it chimes,can it be destroyed,elimanated never to bother me again or is this ?.
Also where do I find the computer,thought it maybe in the passenger side kick panel area but would like to make sure before I start dismantling the truck just on a hunch. Thanks guys.
Old Jun 20, 2006 | 04:49 PM
IA_FordBoy's Avatar
IA_FordBoy
go to your manual.......it will tell you (it has something to do with standing one one leg and playing twister) No really there is a step by step process listed in your manual.
Old Jun 20, 2006 | 05:06 PM
Rocky Mountain Jeff
Hear you on the twister thing I will go through the book again I may have missed it
Old Jun 20, 2006 | 05:22 PM
utahtom's Avatar
utahtom
I believe it is listed under "seat belt chime disable" or something like that...
Old Jun 20, 2006 | 06:07 PM
satcom40's Avatar
satcom40
Well the Question should be for which busser, key or seat.
Old Jun 20, 2006 | 06:13 PM
jgarza250's Avatar
jgarza250
If it's for the seatbelt what you have to do with both doors closed
put key in ignition
switch to on (without turning on the engine)
wait untill the air bag light goes off
once it goes off then you have to buckle and unbuckle the seat belt nine times
(buckle and unbuckle... that's one, buckle and unbuckle...that's two, etc... and by the way you only have a minute to do this)
once you do this then the air bag light will go on and off 4 times very rapidly
once it's done this then you have to buckle and unbuckle one more time and it's done.
Hope this helps
Old Jun 21, 2006 | 05:23 AM
m350's Avatar
m350
I tried the manual's instructions,,did not work for me,,disconnected the plug under the driver's seat,,no more seat belt chime,,,aaahhhhh nice !
Old Jun 21, 2006 | 07:28 AM
Rocky Mountain Jeff
Thanks for the info guys,I found a short term solution to shut the seat belt chimes down, while sitting in the seat,when the chimes started, push the release button in and hold until they stop.You will have to do this each time the truck is restarted. I like the permanant solution the best.The key chime seems to be the tricky one.
Old Jun 21, 2006 | 09:28 AM
06PSD's Avatar
06PSD
disconnect the plug under the driver seat.
Old Jun 21, 2006 | 11:52 AM
Rocky Mountain Jeff
Just spent an hour trying to deactivate the seat belt chimes as the manual says to do do,did nothing but screw up the instrument panel as well as not allowing me to start the truck,it turned over as it would with very low to dead batteries.But yet showed ample voltage...So my conculsion on this part will be to just disconect the plug. Finally fired up but not the way it should have.I still would like to get rid of the key chimes,found a purple / black wire from the ignition to a six wire plug under the dash,when it was unplugged the chimes no longer worked,but to leave this unplugged may deactivate other things ? Buzzed out at the moment play again later.....
Old Jun 21, 2006 | 12:45 PM
NavyPowerstroker's Avatar
NavyPowerstroker
Jeff,
Check out post #33 of this thread. https://www.ford-trucks.com/forums/s...9&page=3&pp=15
Hope this helps you out.
Old Jun 21, 2006 | 12:54 PM
Rocky Mountain Jeff
Tried the nine times instructions also and could not get it to deactivate,I will try it again,Thanks
Old Jun 21, 2006 | 01:39 PM
Gigante's Avatar
Gigante
Originally Posted by NavyPowerstroker
Jeff,
Ahhh, thanks. Three times never worked for me. Now I know why.
Old Jun 21, 2006 | 04:29 PM
jgarza250's Avatar
jgarza250
Jeff,
Check out post #33 of this thread. https://www.ford-trucks.com/forums/showthread.php?t=4949...49&page=3&pp=15
Exactly what I said!
Old Jun 21, 2006 | 04:51 PM
FordGuy0131's Avatar
FordGuy0131
To activate chime
put key in ignition
Hope this helps
Do you just repeat the same process to enable the seatbelt chime?
