'96 A/C replacement NEED HELP
Old Jun 20, 2006 | 01:53 PM
HOTRODVAN's Avatar
HOTRODVAN
I have replaced the compressor and accumulator, but I can't seem to find where the Orifice Tube goes???? It looks like it goes in line on the high pressure side of the Evaporator, but I can't figure out how to get the line apart. Does the line have to be replaced in order to change it out? How neccessary is it to change it out? What about installing a line drier? Thanks
Old Jun 20, 2006 | 04:30 PM
GWall's Avatar
GWall
Sounds like you have found where the orifice tube goes. I don't know what it is called but a special tool is required to disconnect the line. It is the same type of tool needed to remove Ford fuel filters. I bought a set of plastic ones from Napa that work pretty well. Tell your favorite parts house and they can supply what you need.
Old Jun 20, 2006 | 04:42 PM
bohiaa's Avatar
bohiaa
I dont kno how you changed out everything and cant find the Orifice...
It's in line You Must have a tool to reomve the hose,,,,
and PLS change that font
Old Jun 20, 2006 | 07:17 PM
HOTRODVAN's Avatar
HOTRODVAN
OK, thanks guys. It is where I thought it was and I bought the tool and replaced the orfice tube. AND YES, IT IS very necessary to replace that orfice tube! Thanks GWALL
