67-72 Power steering kit
Old Jul 17, 2001 | 09:20 PM
lee's Avatar
lee
Was surfing the net and came across this web site that sells a Power steering conversion kit for 67-72 Fords. Kind of pricey but,. Someone here was asking about these kits so I hope this helps. To answer yer question,..no,...I don't work for these folks. Enjoy. [http://www.jobriteauto.com/accessories_suspension.htm#power_st_conv]
Lee
Old Jul 17, 2001 | 09:21 PM
lee's Avatar
lee
Well the link did not attach. Here it is.
Lee
Old Jul 18, 2001 | 02:04 AM
DritySideDown
Guest
Posts: n/a
Awfully spendy, just done the conversion on my 69 F350 with used(wrecking yard) parts for less then $100.
DSD
Old Jul 18, 2001 | 03:11 AM
Wook's Avatar
Wook
What parts would I need to find to do the conversion? I need to do it on a 73 4x4 w/ a 390 4 spd.
Old Jul 18, 2001 | 02:36 PM
DritySideDown
Guest
Posts: n/a
wook
Mine is a two wheel drive, bur,
Any good wrecking yard with a set of Hollander Manuals can tell what year parts are interchangable. There is a wide range of years that interchange. You will need , PS Gear, PS Pump, mounting brackets, Lines, cooler, Pitman Arm, Steering Shaft or shorten yours. Sure makes it nice.
DSD
Old Jul 20, 2001 | 09:43 AM
sturzinator's Avatar
sturzinator
Rather than start a new thread.... I've located all the power steering parts off a '71 F150 2x4. I'm retro-fitting the conversion to a '68 F250 4x4. My question is this: will everything up to the steering gear box from the 2x4 work on the 4x4? And is there/was there much of a difference between the strength of the two power steering units (1/2 ton 2wd vs. 3/4 ton 4wd). I realize I will have to find tie rods and pitman arm from a 4x4 to make this complete. Thanks!
Old Jul 21, 2001 | 09:35 AM
sweetpea's Avatar
sweetpea
PAR34
WTB - Parts & other
Jun 11, 2014 07:23 PM
lee
May 15, 2014 06:03 PM
gcoxtotal
Ford Truck Parts for Sale
Apr 11, 2014 09:33 AM
MavSprint
WTB - Parts & other
Feb 6, 2013 06:49 PM
