ignition problem
Old Jun 20, 2006 | 10:52 AM
sledge 99's Avatar
sledge 99
ignition problem
I have a 1989 f-150 300 I-6. Check engine light came on while driving. Power would instantly drop and would idle rough. Drive for a few miles engine light would go off and run fine. Couple of weeks later, truck would not start at all. I replaced the iginition module, then truck started 2 times then not at all. I then replaced the pickup module inside the distributor. Same thing, truckt started a couple of times and idled fine. After about 4 min. check engine light came on and stalled. Now will not start. No fire, engine just turns over. Anybody got any suggestions? Could it be a relay or O2 sensor? Is there a way to check the codes? I heard you can use a paper clip for codes check
Old Jun 20, 2006 | 12:44 PM
subford's Avatar
subford
Go to this URL and then repost your codes so we can help you.
http://fordfuelinjection.com/?p=13
Old Jun 20, 2006 | 02:43 PM
tjc transport's Avatar
tjc transport
i ain't rite
check for a broken wire/bad connection on the ignition relay on the driver side fender, near the hood hinge
HawaiianPSD
15
Jun 6, 2016 12:55 PM
McStein
1983 - 2012 Ranger & B-Series
Mar 18, 2015 09:26 AM
TallPaul
Aerostar
23
Sep 27, 2013 01:56 PM
davinci73
1997 - 2003 F150
Nov 20, 2009 09:14 PM
wheressinatra
Dec 19, 2008 12:56 PM
