Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Ford Vs Chevrolet
Old Jun 20, 2006 | 09:48 AM
deltasoft's Avatar
deltasoft
Ford Vs Chevrolet
Tell us the stories you heard about ford or chevy. Share your thoughts....For those new people out there buying trucks....... What advantages Ford has? Chevy?
Old Jun 20, 2006 | 10:30 AM
Ringo Fonebone's Avatar
Ringo Fonebone
Fords last, Chebbys rust. Especially the 67-79 versions.
I have seen so many old Fords unrestored and neglected, still in daily use as work trucks from those years, it is unreal. Hard to find any Chebbys at all... unrestored that is.
One advantage of owning a Chebby tho. The junkyards are jam-packed full of them, you can get any part for one you can imagine, cheap.
Old Jun 20, 2006 | 10:31 AM
JD717's Avatar
JD717
For me, in the compact pickup lines, I've had some pretty crappy experience with an 02 S10. it was/is the truck from hell. now in 3/4 ton trucks, I've driven a fairly nice Chevy 2500 with the 5.7 and TH700 tranny, quite a nice work truck, no major problems or anything.
in Ford, I had an 83 Ranger, only problems I ever really had was the constant oil leak, and the fuel pump died on me once, oh yeah and a battery cable. other than that, it was one of my ALL TIME favorite trucks. would I buy another? in a heartbeat, no questions asked.
Doesnt matter what brand you buy, theres a lot of good ones, and some that are just nightmares from the get go. every brand is like this, Ford, Dodge, Chevy etc.
Old Jun 20, 2006 | 11:01 AM
deltasoft's Avatar
deltasoft
how come i havent heard of big issues with engines on chevys like we are hearing with all these recalls for ford?
Old Jun 20, 2006 | 11:11 AM
pfogle's Avatar
pfogle
Because Chevy does a better job of covering it up. The '99 thru '02 trucks had a serious piston slap issue, the early d-max/allison combo had a software glitch where under load the trans would drop to first at higways speeds and detonate the engine, they are out there. You just almost have to work for a dealer to find out about them.. The early 229 (3.8) and 4.3 engines had crank and cam issues. I think that about 2 out of five chevys produced after about 1979 smoke. The 2.2 used in the late 90s and early '00 have some valvetrain issuses. I've heard several in cavis and s10s that rattle so bad they sound like a diesel at idle. These are just a few of them.
Old Jun 20, 2006 | 04:50 PM
Beast12's Avatar
Beast12
Thread moved to the Ford vs Competition forum.
I have the power to dump this thread in "Fred's" lap.
-Matt
Old Jun 20, 2006 | 05:54 PM
MofW's Avatar
MofW
This is why I love this site. You learn something new every day. Please tell us more, I've never heard of the d-max/allison problem you have discribed. Do you work at a dealer? Or did you hear about this from another source? My father-in-law is a parts manager at a Chevy dealer and I ask him all the time about the duramax as far as what they see come in and he's never seen anything like what you're talking about. A few injectors here and there but that's about it.
Old Jun 20, 2006 | 07:42 PM
moldman7n's Avatar
moldman7n
Talking
Yes. Chevys never have any mechanical issues. No Duramax has ever had a failure except for a few injectors.
Old Jun 20, 2006 | 07:59 PM
J..D's Avatar
J..D
The only issue with the older 4.3's was no balance shaft until 92 and the crank/cam where fine but they did have bad valve guides which also was fixed in 92. My family had 3 4.3's 88-91 all had 180-200,000 when we sold them with no problems. My 89 Ranger 2.9 went 160,000 when I sold it ran good,was much better than the 3.0 ranger.
Old Jun 20, 2006 | 08:01 PM
DOHCmarauder's Avatar
DOHCmarauder
Please school us on "all these recalls for Ford"..........otherwise, this post (and the whole thread) is very troll like.
Old Jun 21, 2006 | 07:53 AM
70blue's Avatar
70blue
Yes deltasoft please do school us. I can tell you one reason you don't hear of many recalls from Gm. They put out a technical service bulletin that said using a quart of oil in 2000 miles was normal for an unloaded vehicle. In reality they should have recalled those engines that had pistonslap. The trouble was if they would have recalled that many engines there would no longer be a chevy to compare ford to.
Old Jun 21, 2006 | 07:59 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
they put out a technical service bulletin that said using a quart of oil in 2000 miles was normal for an unloaded vehicle.
Don't check the Service manual on the PSD then... (1quart for 1100miles if I recall correct)
Old Jun 21, 2006 | 08:06 AM
70blue's Avatar
70blue
I do not have any experience with diesels so I cannot say if that is the norm or not. Gassers on the other hand 1 quart in 2000 miles I believe is excessive.
Old Jun 21, 2006 | 09:58 AM
Red Star's Avatar
Red Star
Other than first 3 years of Thunderbird, Ford never had car that could compete with Corvette.
Old Jun 21, 2006 | 10:00 AM
jimandmandy's Avatar
jimandmandy
Ringo, 67-72 Fords rusted so badly that there are almost none left here on the left coast, while there are still plenty of that vintage GM trucks around. 73-on the opposite is true. GM started using water-based paint at the Fremont plant in 1973 and the results were awful for a few of years while they perfected it. Rusting issues are different here because they dont salt the roads. Coastal humidity tends to rust from the top down instead of from the ground up.
I also notice plenty of early 80's Rangers and Toyotas still on the road and almost no surviving S-series GM, Datsun/Nissan, Mitsubishi/Dodge, etc.
Jim
