Sponsored by: Real Truck
Air Conditioning
Old Jul 28, 2006 | 04:43 PM
mizzitch's Avatar
mizzitch
I just had a similar problem with my 99 SD. The low pressure/ compressor cycling switch was bad.
Old Jul 28, 2006 | 04:56 PM
rwilimo's Avatar
rwilimo
Originally Posted by dougb
My compressor has a gap of .028. I pulled the clutch but did not see a shim. Where exactly would it be located?
Thanks guys,
Doug
A lot of times the shim sticks inside the clutch disc, use a pick or small screwdriver and stick it through the bolt hole from the front of the clutch a little crooked (against the edge of the hole) and see if you can push the shim out of the the clutch. It will not be tight, but often it has some grease holding it in place. All ford compressors have a shim from the factory.
Old Jul 28, 2006 | 06:42 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
rwilimo, I knew there was a reason we keep you around... real experience
Old Jul 28, 2006 | 07:54 PM
rwilimo's Avatar
rwilimo
Hey, somebody's got to do it
Old Jul 29, 2006 | 12:41 AM
SpringerPop's Avatar
SpringerPop
I re-shimmed my compressor clutch plate last week for the exact symptoms described at the beginning of this thread. My air gap was around .040" when I started, and the clutch just wouldn't pull in after a few minutes of operation.
After the re-shimming, it works "as advertised"!
See Post#2 at:
https://www.ford-trucks.com/forums/s...d.php?t=510494
Pop
Old Jul 29, 2006 | 01:26 AM
JROSCO6's Avatar
JROSCO6
There is a reflash for this problem i was told by my friend.He did mine today we will see if it works. I just got the truck last week.
Old Jul 31, 2006 | 08:21 PM
dougb's Avatar
dougb
Got it.
Thanks
Old Aug 1, 2006 | 03:01 AM
glsurratt's Avatar
glsurratt
I had the problem yesterday on an '06 with 325 miles on it. Started on a short trip and about 20 minutes into the trip, sitting at a stop light, the A/C started blowing hot air. As soon as I started rolling again, it went back to cold and there were no problems the rest of the day. Outside temp was about 85, A/C was set to Auto at 70 degrees.
I also thought I smelled burning rubber, but it didn't last long enough to be sure and since there were no more problems, I didn't worry about it too much. Is it possible the compressor siezed for a minute causing the belt to rub?
Old Aug 1, 2006 | 09:17 AM
beej1024's Avatar
beej1024
Seems like a close thread, so I will post my problem here. Last week my 03 F250SC started acting odd. With the AC on, it would continue to blow cold air, but it would randomly switch between the vents and the defroster. Id I monkeyed with one of the vents by shutting it and opening it, the air would start to flow out the vents again. When it switched there was a platic type clicking sound from inside the dash.
Brought it to the Stealer who told me it's a broken part, 9h465, they call it a thermal air control valve. $400.00, not covered by my Ford NewExtraCare warranty. My trucks is 3.5 years old with 26K miles on it.
Old Aug 1, 2006 | 01:15 PM
krewat's Avatar
krewat
Please post a new thread.
Old Aug 1, 2006 | 01:59 PM
ExcursionPSD's Avatar
ExcursionPSD
Vacuum controls outside air / recirculate door. It also operates the floor vent/ dash vent/ windshield defroster, doors.
The hot/cold blend door is electronically operated.
Old Sep 9, 2006 | 05:51 PM
s2racer's Avatar
s2racer
my ('99 f-350 sd) air has the problem of a/c working for a while then blowing warm air, then after 10-15 minutes resumes cold air blowing. the air gap appears fine, and the tech could find nothing wrong. however, i finally was able to check the compressor when the warm air came on, and the compressor was not turning (it is working when cold air is blowing). this doesn't seem like it would be a vacuum problem, so my question is: is the compressor shot, or about to die? as an aside, i also have the warm air blowing through the vents when the a/c isn't on (which does seem like a vacuum problem). any thoughts?
thanks
marc
ptmares
Aug 26, 2012 11:19 PM
race39
Mar 29, 2012 11:59 PM
funzjb1
37
Mar 29, 2010 06:04 PM
krankshaft
Aerostar
Sep 8, 2005 10:13 PM
canelane
Jul 9, 2003 09:08 AM
