hydro boost
Old Jun 19, 2006 | 10:01 PM
GR8TWHITE's Avatar
GR8TWHITE
Unhappy hydro boost
well have some bad news, saw a puddle under my '06 f250ccsb today and traced it to my hydro boost. anybody else have this problem? also my exaust manafolds are leaking (black soot around ports) do they have gaskets or are they machine fit?
Old Aug 21, 2006 | 01:12 PM
2006 PSDamarillo's Avatar
2006 PSDamarillo
my 2006 250 4x4 just had the hydro pump go out it did not leak it worked intermintly the power steering pump is leaking from the back and i think the rear main seal is leaking also the rear end is linking at the can the truck is at ford right now my exhaust is got the same black soot coming from the exhaust manafolds
but when i start the truck up and fee for the leak on the exhaust i do not feel anything you only have 1 min till it is so hot
i will let you know what happens when the truck comes back
Old Aug 21, 2006 | 01:15 PM
bedwards's Avatar
bedwards
exhaust has no gasket I think some soot is common
be
Old Aug 21, 2006 | 02:34 PM
Skweeker's Avatar
Skweeker
I read something about exhaust manifolds leaking at the cylinder head. The mainfolds are mounted to the heads without gaskets at the factory. Ford has a gasket to help solve the leaking exhaust manifold. Not sure if it is listed for all engines but I saved the part number.
Exhaust manifold gasket: 5C4Z-9448-A
Old Aug 21, 2006 | 03:10 PM
'88_F-150's Avatar
'88_F-150
If you bring your truck to ford and complain they will put gaskets in since it came without gaskets. The job isnt too hard i did them my first day at ford
Old Aug 21, 2006 | 07:00 PM
03f2506.0's Avatar
03f2506.0
Question
'88_F-150: Want to take the drivers side manifold off to put in EGT probe. Don't want to take any chances of metal chips getting into the turbo. Can you get at all the manifold bolts from underneath or do you take the plastic fender well off? Thanks in advance for any info you can give me.
1badton
Dec 31, 2022 12:56 PM
DocMartinFNG
Feb 9, 2015 09:51 PM
mofoco1
19
Oct 25, 2014 10:08 AM
dieselman86
Oct 18, 2014 09:35 PM
wheelie31
Feb 20, 2013 09:23 PM
