Hey I am looking into lowering my 69 truck 3/4 inches. I can't find any place that carries parts to do this can anybody help me with this? No I cannot be dissuaded from going this route so don't try cause this is for better handling. I'm not going so far as to drop it in the weeds where it would rust.
Adam, Welcome to the best Ford truck site on the web. Now since you don't want anyone trying to stop you from your madness, how about splaining to the rest of us about your 3/4" theory, and why you THINK it will improve your ride. Tell us a little more about your truck that has the bad ride.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
The 3/4" theory as you call it is based on simple physics. I will lower the center of gravity of my truck bring closer to the road thus making less likly to lean during hard cornering.
are you talking 3/4" or 3 inch front and 4 inch rear? There is a strong redneck/white trash influence on this board sometimes (no offense, but if someone wants to lower their truck let them and no John not talking about you I value your opinion, just from what I remember of old posts) so if you want to do it dont let anyone dissuade you. you may try http://www.aimind.com they have 3" drop I-beams for about $400 and a flip kit for the rear axle for about $150 It's pretty easy to see the dropping the center of gravity makes a big difference in cornering. One of the Motor Trends a while ago I believe it was motor trend anyways was talking about the redesigned viper and how glad they were to lower the CoG 3/4" because of the improvement it would provide in handling, so a 3.5" drop would obviously help, especially in conjunction with sway bars.
Hey FE, I resemble that remark. Yall keep driving over from the trailer park and trowing your empties in our yard and call it hyway beautification. :-)
#1 Tarheel Ford truck driving Redneck. Oo Oo
John
jowilker
66F100s Rule
Now yall listen here, anybody talking about lowering a truck is crazy. Why do they make 4x4's? So you have the clearence and the power to go where ever you need to or want too. Personally no matter how much you lower a truck it is a waste of money and a waste of a good truck
That's true of a 4x4, but not a 2wd, at least one that won't be used for towing. Factory ride heights are compromises. You need plenty of height for off road use, and long travel for heavy hauling (if you want to avoid spine crushingly high spring rates, anyway). But lower ride heights provide better and safer handling. If he has a 2wd drive truck that's used as a daily driver or commuter, and he never intends to take it off road of haul anything heavy, why not lower it a few inches? My 2wd F100 is at the factory height, and I intend to keep it that way just because I like the view and don't want to spend the money to lower it, even though I don't haul big loads and don't take it off road. But if he wants to lower his, he should
ksd
69 F100 Explorer lwb 2wd FE 360 C6 3.25:1. WANTED: straight/clean styleside long box w/aux fuel tank for 67-69 F series.
As someone with a little engineering knowledge, lowering a truck 3/4 inch will not effect handling unless your sitting on the pole of the "Brickyard 400" this weekend. Since the bulk of the wt of your truck is at or below the frame (lower part of the engine block, axles wheels, trans, etc.) and there is very little weight up high (just your cab); lowering 3/4in will effect your center of balance on a 73 to 79 F-150 about an 1/8 of an inch. If you want to do it for "appearance" than go ahead but, it's not going to help your handing.
Doop <
76 F-100 Custom (96K Original North Dakota miles) 360-C6 All stock
64 F-250 (Bought from the north slope of Alaska) 292-T18 4 speed
By "3/4 inch" he probably meant 3 inches in front and 4 in the rear. That's pretty standard on trucks, which come from the factory set several inches higher in the rear.
Also, where the weight is doesn't matter at all so long as it isn't "unsprung" weight we're talking about. Lowering the truck by three inches will lower the center of gravity by very close to three inches.
ksd
Lowering the CB doesnt effect handling (unless you are using downforce as in NASCAR) suspension systems, weight distribution, speed, radius of turn and arc of turn determine handling. If center of balance determined handling, than a 1978 Ford LTD 4-door would be the best handling car on the road since it's center of balance is far lower than pickup. However, make a sharp turn at 70 mph in an old LTD and it leans far more than a Ford truck, why? softer suspension!
If you want better handling than upgrade your springs, stocks, and balance the weight front to rear.
Here's a simple AV formula to figure center of balance:
Adam,
I have a 69 stepside I,d like to do this to my self let me know how it goes.Would you know any thing about suicide doors and shaved handle kits ? Also been thinking about choping the top but not sure about that yet.
