stupid gauge question
Old Aug 6, 2001 | 04:02 PM
rusty68's Avatar
rusty68
okay- bear with me, i'm mostly clueless.
i recently wired up a cluster of auto-meter gauges. oil pressure, water temp, and voltmeter. (all electrical gauges) they work great, and look sharp.
my question is...
can i hook the stock water temp gauge and oil pressure idiot light up to the auto-meter sensors? i hate seeing my poor stock water temp needle just sitting there, doing nothing.
thanks,
sam
Old Aug 6, 2001 | 04:15 PM
otto's Avatar
otto
possibly, you have to lose by trying just hook it up and get it to temp and see if it reads anything
Old Aug 6, 2001 | 07:35 PM
Like M. Fords's Avatar
Like M. Fords
It may be possible for your Ford guages to work with the Autometer senders, but you will never be able to share a sender with two guages. The reading would not be accurate because one guage would be trying to read a resistance at the sender while at the same time recieving a signal from the other guage that is also trying to read a resistance. The only way to safely and accurately have both guages working is to have a sender for each guage. Not a big deal for oil pressure, just add a tee. But for water temp, you will have to find a second location. Not sure what engine you have, but the fitting on top of a 390's manifold that goes to the heater core would be a good place to drill & tap for the size of threads the sender has.
Old Aug 7, 2001 | 10:28 AM
beartracks's Avatar
beartracks
Riskit
Jan 5, 2017 12:22 AM
treverd
Sep 21, 2016 09:13 PM
Fords & Whalers
Aug 20, 2016 12:18 PM
Bmccord03
Aug 16, 2015 11:12 AM
410 Highboy
Apr 14, 2014 07:49 PM
