.My FE had a leak .Turned out to be the sender mounted to the oil filter mount .Oil pressure gauge shows on the high side now .
I would like to keep the stock instrument panel , but add Autometer gauges .
There was a member that fabricated pillar gauge mounts .Are any piller mount gauge housings available for a 75 ?
Not any off the shelf that I know of.... Maybe adapt one spec'd for the Bullnose F-Series?
Btw, that pillar gauge pod mount thread is available in the tech thread sticky.
Thanks HIO silver .Would prefer to adapt rather than fabricate if you know what I mean . Looking for the easy way . My end result will work and not look hokey .Just might take awhile to get there .
Thanks HIO silver .Would prefer to adapt rather than fabricate if you know what I mean . Looking for the easy way . My end result will work and not look hokey .Just might take awhile to get there.
I dig it. I think all we like to see is that it is done with good workmanship.
