95 Ranger CMP Sensor Error
Old Jun 19, 2006 | 07:52 PM
tonymusc's Avatar
tonymusc
Hi! I have a 95 ranger with the 3.0 2wd and automatic. The check engine light came on and the code was "camshaft position sensor A bank 1 circuit malfunction". Is the CMP sensor easy to replace? This came on after I fixed a vacumn leak. There is also a strong smell of gasoline at times after its been running. The truck runs great after I fixed the vacumn leak. Should I tackle the CMP sensor? Will I need any special tools? Thanks.
Old Jun 19, 2006 | 10:57 PM
Rockledge's Avatar
Rockledge
Welcome!
This thread has a wealth of information regarding the CMP sensor and the 3.0L:
https://www.ford-trucks.com/forums/s...hreadid=202004
The gas smell could be a leak in the EVAP system.
Old Jun 20, 2006 | 09:00 PM
tonymusc's Avatar
tonymusc
Ranger CMP Mechanic
Thanks Rockledge. Your right, a bunch of good information. The sensor was bad unfortunatley the snc shaft was also sheared off. The light was on for only one day but thats all it took. I am not up to changing the shaft. I barley got the sensor out. No room. Who would you recomend me take the truck to change out the shaft. Would a Firestone be able to do it or should I take it to the dealer. Know any good mechanics in SW Houston? Thanks.
Old Jun 21, 2006 | 09:57 PM
Rockledge's Avatar
Rockledge
Any qualified shop can handle it.
Old Jun 22, 2006 | 06:10 PM
tonymusc's Avatar
tonymusc
Its funny. I replaced the cmp sensor and Snycroniser and the check engine light is off now but the engine still runs about the same. I thought I would get a little more acceleration out of the truck. It idles fine. Maybe thats all the 3.0 can give.
