Tranny Temp
Old Jun 21, 2006 | 08:38 AM
Sycostang67's Avatar
Sycostang67
Originally Posted by Casey
That chart is completely useless for any modern transmission or ATF. If you are running a 1960's fluid, then pay attention to that chart.
This was the quote that kind of upset me, and I just noticed you didn't even make it. Guess I was flipping through posts too quickly. After going a little slower and double-checking who posted what, you are right and I apologize, you were courteous in mentioning the age of the chart as well, please forgive my foolishness. I just put my blinders on after I got upset. You are also correct about the giving of misinformation, we don't really need any of that. I guess I will get rid of that link now, or at least not expect it to apply to everything(I forget things are improved with time). At least I learned something from all this. Now I am gonna go cook some of this egg I got on my face.
Old Jun 21, 2006 | 02:58 PM
jschira's Avatar
jschira
There is a thread going in the 1999-2003 PSD Forum about this subject, and except for the Ford 248* thing, the "middle ground" that seems to be emerging is that "normal" can be considered as high as 210*-220*, so operating up to this range, rather than 180* or so, is acceptable.
Like I said. I am going witht he Ford gauge (or the idiot light in my CTD). When it goes off, I'll worry. Until then, I will just change the tranny fluid per the severe service schedule.
Old Jun 21, 2006 | 05:10 PM
Sycostang67
I try to stay in the 180-200 range, but is it the fluids that allow for the temp, or are the trannies made today being built with different materials that make them withstand more heat? I run MERCON V in my 85 F-250(C6), and while I hope I never get to 248* it would be nice to know which would be the weak link, chemical or mechanical.
Old Jun 21, 2006 | 08:44 PM
jschira's Avatar
jschira
I think both. (My opinion).
Old Jun 22, 2006 | 08:02 AM
Casey's Avatar
Casey
I agree with jschira. It's both better materials in the trans and better fluids.
Old Jun 22, 2006 | 09:16 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
....and I STILL say "if you're gonna tow, use a tranny cooler". The cooler is a danged cheap insurance policy.
Old Jun 22, 2006 | 07:20 PM
jschira's Avatar
jschira
My PSD has 2. Oil to air and oil to water.
Old Jun 23, 2006 | 09:48 AM
Sycostang67
Same here, but I just bypassed the rad. cooler, and now it runs cooler. Gets to operating temp quicker, but doesn't get as hot towing anymore. I pulled 2.5 tons of hay last night, and it never got to 200*. Now I know that 200* isn't much for you guys with newer rigs though, but I am quite happy with it.
Old Jun 23, 2006 | 11:17 AM
jschira's Avatar
jschira
I am pleased.
Old Jul 2, 2006 | 02:02 AM
fasthauler's Avatar
fasthauler
My 77 F250 C6 has two coolers on it. I think I am going to pull the lines off of the radiator and put the largest cooler I can buy in place of it. I have a 22K aux cooler mounted under the vehicle and I still can't keep the tranny fluid under 220. The gauge is mounted in the tranny pan and under hard pulls up hills the tranny will get up to 250+ the tranny has 220k miles on it and is still working ok, but it still makes me nervous running that hot. I have been using merc V in it ever since the stuff came out. Also I change out the fluid every 25K and run an external filter.
Old Jul 19, 2006 | 08:54 PM
rmarquet's Avatar
rmarquet
My E4OD took a dive a couple weeks ago, so I had a shop install a Jasper rebuilt E4OD, along with a temperature gauge (and a drain plug to make fluid changes easier). I believe they installed the gauge sensor in the pan. The Jasper transmission includes a new cooler, btw.
When I talked to them today, they said they've taken it on several test drives and the temperature hasn't climbed above 150 degrees. (This is a 9,000 lb motor home.) Since I'll be towing a car with it, it sounds like I should start to worry around 220 degrees or so. However, if it's doing 150 solo, hopefully 220 will be a pretty rare occurrence even when towing.
The transmission's first test will be to pull a car over the same mountains that caused the other one to die. It'll be interesting to see what the temperatures do in those mountains, since they're about the worst I will encounter in my travels.
Old Jul 21, 2006 | 08:46 AM
460me's Avatar
460me
79 460 c6 Trailer Specail.I tow 87 24' Komfort 5'er,on the flats at 60-65 the temp is 150 and up hills it climbs to 180.
Old Jul 21, 2006 | 06:27 PM
  #28
rmarquet's Avatar
rmarquet
Brand new (well, rebuilt) Jasper E4OD in my motorhome, with a gauge in the pan: it does about 150 degrees solo, I had it up around 165-175 when towing in the mountains with O/D off... then 180-190 sitting in traffic on the DC beltway.
Interesting, but not surprising that sitting in traffic (after working hard all afternoon) would be what got it warmest. It was fine even climbing the hills on I-70 near Fredericksburg, MD.
